Don't wanna hurt your feelings but that's not really a place to try to save a buck.
This is a discussion on steering bearings within the General forums, part of the Caferacer.net Forums category; Can I use standard 1/4" ball bearings as replacements on my old honda's steering stem? Or is there something special about the ones you pay ...
Can I use standard 1/4" ball bearings as replacements on my old honda's steering stem? Or is there something special about the ones you pay a premium for at the dealer? Unfortunatly I can't afford $40 needle bearings right now
the thing about that particular ball bearing design is that it is somewhat forgiving and has adjustment built right in
I'd measure the Honda balls and if they are within ten thou or so
go for it
It wouldn't surprise me to learn HOnda used same old same old 1/4 balls anyhow, maybe they aren't 6mm or maybe they are
I dunno
however, my SOP is to toss loose balls in a jar and never put any forks back on using them
timken bearings are just the right thing to do
so if you were nearby, I'd give you a hand or two full since the only things I actually use them for tend to be problematic with trouble following
I measured them with a micrometer at .250. One of the previous owners may just used whatever he could find. I just didnt know if there is a difference in materials. I figured they were all a high carbon steel so it shouldnt make a difference whether they were marketed for a bike or not.
I've been taking those pesky bastards out of steering heads for years and the only bad ones I've found have been ones that had been run dry for a long time, or those which had been run loose
if it goes together and feels good
go for it, I would if I didn't have timkens and I've had days I couldn't afford a set either
who hasn't?
my guess is a good roller ball is a good roller ball
you could always test them by smacking them with a sharp file
if a file won't touch them and they don't shatter
I'd call it good within reason
I like the timkens because they are easy...but you talk to some real chassis gurus and they'll tell you the old school balls are better. Something about the angle of the loading...the way the tighten up compared to timken...blah blah. The problem with the balls is they don't take shock well..tend to dent the races creating that notchy feeling.
mcmaster carr.com
Part Number: 9528K15 $4.12 per Pack of 100
Type
High-Precision Bearing Balls
System of Measurement
Inch
ABEC Precision Bearing Rating
Not Rated
Ball Material
E52100 Alloy Steel
Diameter
1/4"
Diameter Tolerance
±0.0001"
Sphericity
0.000025"
Rockwell Hardness
C60-C67
Specifications Met
American Society for Testing and Materials (ASTM)
ASTM Specification
ASTM A295
Note
Balls are grade 25.
© 2008 McMaster-Carr Supply Company. All rights reserved.
mcmaster carr.com is where I bought a set for a old three wheeler I had years ago.
Honda wanted THREE TIMES the price for the same bearings. For that price I could probably have gotten stainless steel!
I spent like $10.00 instead of $30.00!
Tapered bearings are the way to go if you can.
I doubt I could be convinced that ball rollers, caged or loose, are better than tapered rollers for a steering head
if they were indeed
all bikes produced would use them and none made today do as far as I know
and a real treat if you are running balls
are using the caged ones
I've used them in Brit bikes before when an owner did not want to "compromise the originality of their machine ..... bleh....
and the caged balls do have a Triumph Factory part number and will fit all of the 70 and back unit framesquote:Originally posted by jbranson
