New Guy, Project bike with Plenty of ?s :) - Page 2
This is a discussion on New Guy, Project bike with Plenty of ?s :) within the General forums, part of the Caferacer.net Forums category; Well done on breaking 100! Question on rearsets, should I go new or try and find a good set off a modern rocket?...
Results 11 to 20 of 25
  1. #11
    zr140th's Avatar
    Apr 2008
  2. #12
    May 2006
    Detroit-ish, MI, USA.
    fzr600 controls are what you want. Get thee to eBay.
  3. #13
    , Decrepit and Decomposing, .
    When I got this bike the controls and the highly bizarre JD green with Whacko blue paint scheme came with it
    I do not know from whence the controls originate but I'd guess something mid 90's
    I didn't like the "mounting" attempt since nothing was square true nor did the fasteners square up and they there was this matter of the nuts fighting the whole/hole ugly mess on the back side
    Here it is shown after I made a link rod from stainless bar stock
    the other side and it really looks innocent and ok enough but it was really bad
    so I got sick of it and broke out the whiz wheel
    by the way, have you ever seen a goofier or sillier folding kicker?
    I molested that brand new yet totally stupid part with extreme prejudice
    got both sides finished nice and smooth
    anyhow, I was thinking about how much I like to drill holes, spinning up threaded bungs, and even welding
    so I did
    they finished out acceptable and I'm much happier with the very solid mounting of them
    good luck and thanks on the hunnert
    btw...... if you end up facing mounting something like this
    there are easier ways to do it, I could have much more easily welded threaded or unthreaded tabs to the tubing and not had to fuss with those reasonably tedious weld joints or drilling huge holes in that thin wall tubing
    In fact, I actually made some out of 3/8 steel, had them contoured to fit up to the tubing..... but the desire to penetrate something over-rode that plan and dictated the mission from that point on...
    zr140th's Avatar
    Apr 2008
    Sorry guys, I was wrong on the 79' listing, it's a 1980 model.
  6. #15
    oh..... well then...... I take back everything I posted
  7. #16
    zr140th's Avatar
    Apr 2008
    LOL. Thanks for the input...I'll have to check the pics you posted at home - damn government computers!
  8. #17
    Jul 2006
    New Castle, PA, USA.
    HackASaw:
    About your rearset mounts there - isn't that kind of dangerous drilling big holes right through the frame like that? I talked myself out of doing that very thing you've done there...
  9. #18
    quote:Originally posted by borzwazie
    HackASaw:
    I think he welds the bungs back in in which case being mostly solid pieces it should restore a large portion of the rigidity back if not more. Plus there are frame tubes that you can drill that are not structural (like the passenger peg mounts on a cb750).
    it can dangerous if you are a poor engineer and welder
    otherwise it can be done and the result can actually be stronger
    would you like to see a featherbed with many many bungs inletted and welded in place?
    then you can see how scary it is, in fact I could show you pix of these rear sets welded if you like.
    have to dig up the pix
  11. #20
    Jul 2006
    yeah, that would be cool. It looked like you just drilled a through-hole and stuck a bolt through. welding a bung in sounds much better...
  1. cb100 project bike
    By edakotaf in forum Parts For Sale
    Last Post: 05-03-2012, 09:15 PM
  2. Project Bike
    By tophogdog in forum Wanted
    Last Post: 03-12-2011, 03:24 AM
  3. My project bike
    By Beenie in forum Project Builds
    Last Post: 09-25-2008, 06:57 AM
  4. project bike
    By desmoduc in forum Wanted
    Last Post: 08-22-2007, 07:46 AM
  5. my race bike project
    By joe c in forum Technical
    Last Post: 10-04-2006, 08:13 AM
