car brake questions fot the all knowing board
This is a discussion on car brake questions fot the all knowing board within the General forums, part of the Caferacer.net Forums category; is there any reason i cant turn my own rotors on my lathe?? jc...
Results 1 to 10 of 12
    Moderator joe c's Avatar
    Mar 2002
    , , Turkey.
    72CafeRacer's Avatar
    Jun 2008
    hmm..dont see why not..may want to measure the thickness first to make sure you have enough for the enitial turn, and some extra incase it doesn't turn out so good. As long as its an even flat cut and the rotor stays balanced, it should work.
    Mar 2002
    , , Turkey.
    thats what i was thinking. my rotors are 120 bucks a side. so i figured a few minutes on the lathe wasnt going to kill me. easier than putting it on stands, than taking them someplace.
    j
    Member dubyaohohdee's Avatar
    King George, VA, USA.
    $120 per side? I just had mine done (Ford Ranger) i think i paid $10 per rotor. If you meant $12 then just let the shop do it.
    dubyaohohdee
    W____o_o_d
    Jun 2008
    I think thats the replacement price...I hope...it averages around 10-20 bucks to have rotors turned, any higher price and your paying to much. It usually takes about 20min a rotor. I just take mine to O'Reilly's, drop them off, get lunch and pic them up and pay my 40 bucks to have all four done.
    , Decrepit and Decomposing, .
    because they will vibrate/chatter if you do not dampen them and cut both sides at the same time
    both sides must also be parallel so the only way to do this is to use a brake lathe
    unless you can rig up two fully adjustable cutters on your cross slide
    then all you need is that lead weighted rubber band for it's diameter
    Senior Member mikeo's Avatar
    May 2002
    Lockport, NY, USA.
    Joe,
    It can be done but it's a pain in the ass. First you need mount the rotor and indicate, on the lathe, the part of the rotor that faces on the truck's spindle to probably .0005" (maybe more but check the spec for total runout). Then without moving anything cut one face. If you can change the cutting tool to face the other side of the rotor without dis-mounting it then you don't need to re-indicate and just face making sure you don't thin the rotor to less than the min spec. If you can't and have to flip the rotor over then you need to indicate to the already cut side to .0005" (or less) and cut. It's a bunch of time and the reason why brake lathes were invented.
    Have fun,
    Mike O.
    Senior Member parks61's Avatar
    Jan 2006
    what mikeo (jedi mind-f master) said.
    -parks
    I\'m not handsome
    Mar 2002
    , , Turkey.
    ok, i thought itd just be a matter of indicating of the flat spindle area, flatening one side, then flipping it, squaring it again, then flattening the other side.
    cheapo replacements are about 120 per side. i bought em new last time, and then proceeded to gouge them in new jersey. then drove home not wanting ot do a brake job at the track.
    ive been riding the bike ever since. hmmmmmm guess its off to the shop with em. i just dont have a good place to leave my truck on stands. oh well.
    thanks for the info guys. as always, good advice.
  1. Questions about cb200 front brake
    By fox8991 in forum Technical
    Last Post: 09-10-2010, 03:44 AM
  2. brake modification questions
    By txchainsawgogi in forum Technical
    Last Post: 03-27-2010, 11:40 AM
  3. I'm not well liked on the SOHC board
    By Geeto67 in forum General
    Last Post: 12-23-2007, 02:05 PM
  4. Dead Board
    By aaron in forum General
    Last Post: 07-12-2005, 08:47 AM
  5. Knowing Jack Schitt
    By Chikor in forum General
    Last Post: 12-28-2002, 10:20 AM
