Winterizing
Winterizing
This is a discussion on Winterizing within the General forums, part of the Caferacer.net Forums category; What do you do to your bike to winterize it after a long riding season? Drain tank? Remove battery and hook to battery tender? Change ...
Results 1 to 4 of 4
Thread: Winterizing
    Senior Member ZouLou's Avatar
    Aug 2007
    St. Louis or Columbia, Missouri, USA.
    Winterizing
    What do you do to your bike to winterize it after a long riding season? Drain tank? Remove battery and hook to battery tender? Change oil? Drain float bowls? What else?
    1979 Yamaha XS650 Special
    https://www.caferacer.net/forum/topic.asp?TOPIC_ID=12991
    Chikor's Avatar
    Mar 2002
    don't drain the tank... fill it to the top..... that way no rust will be able to form... hell just put some good enduro tyres on and ride it through the winter, maybe some studded tyres...
    Aug 2007
    well the bike will be getting worked on so riding is out. Should I put any fuel stabilizer in the tank? Should I still drain the float bowls?
    Chikor's Avatar
    Mar 2002
    yeah it's always a good idea... if you are working on the bike and taking the tank off then take some marvel oil and slosh it around the empty tank to coat the inside.... if the tank is staying on the bike then put some stabil in, cann't hurt...
  1. winterizing a motorcycle
    By cafe350 in forum Technical
    Last Post: 10-28-2010, 04:31 PM
