Maybe you guys can help me out.
This is a discussion on Maybe you guys can help me out. within the General forums, part of the Caferacer.net Forums category; You guys seem to know more about engines than most on TT, so I'll ask here as well as TT. My 05 DRZ400 is making ...
Results 1 to 7 of 7
    Senior Member TonyDanger's Avatar
    Mar 2008
    Klamath Falls/Edmonds, OR/WA, USA.
    You guys seem to know more about engines than most on TT, so I'll ask here as well as TT. My 05 DRZ400 is making a strange ticking noise that I don't believe is the valves or cam chain. The bike doesn't make a ticking sound at idle, under acceleration, or cruising. It only makes the sound during engine braking. If I pull in the clutch, the sound stops.
    The tick itself isn't normal. It sounds like a metallic heartbeat. Again, only on decel engine breaking: tick tick -- tick tick -- tick tick. The sound doesn't really seem to be related to engine rpm as the the speed of the tick only marginally slows down, almost not even noticeable in time.
    Do you guys have any ideas? The noise came on suddenly, it didn't grow louder as time went on, it was just there one day.
    Thanks guys
    I was right in the middle of a fucking reptile zoo, and somebody was giving booze to these goddam things.
    Member scott.v's Avatar
    Jan 2008
    Melbourne, Victoria, Australia.
    What about a loose drive chain hitting in the chainguard?
    1974(?) CB200
    loose drive chain?
    loose clutch pressure plate bolt?
    does your engine burn any oil?
    Mar 2004
    Raymond, NH, USA.
    Some DRZ's had bad cam chain tensioners. The fix is to install a manual cam chain tensioner.
    The DRZs are noisy bikes. Have you checked the valves yet? I don't think they have an auto-decompression valve. If they do, that could also be what's making the noise.
    I have a DRZ400 as well. A 2002 E model. Love the bike, just wish it had a 6th gear.
    I probably should replace the cam chain on mine. I beat on it quite a bit.
    Check out the Thumper Talk forum. Plenty of DRZ knowledge there.
    Moderator joe c's Avatar
    Mar 2002
    , , Turkey.
    I think the tt hes referring to is thumper talk. but yeah, they are kick ass over there.
    Mar 2008
    I'm about to check the valves soon, maybe this weekend. That is a few votes for a drive chain issue now so I'll check closer into that as well. I didn't mean to diss ThUmper Talk, they are knowledgable. It's the DRZ section seems to be riddled with a lot of know it alls that can get a good response deluted in a hurry. Don't have that problem in the XR section.
    Unga, I should do the MCCT but they seemed to fix a lot of the issues with it in later DRZs. It's only a fifty dollar item, but that's cash that could go to the CB!
    Geet, no burning oil. I'll check valves though.
    Nov 2008
    They do have an auto decompressor but its centrifugal like the ones on TL1000 (and the ATV's )
    Not sure if it has a torque limiter clutch though, haven't been inside one yet (well, not bottom end anyway)
    Carb slide flutter maybe or an air leak at silencer joint?
    PJ
  1. FZ guys
    By mickey356 in forum General
    Last Post: 08-28-2011, 10:32 AM
  2. How do you guys do it?
    Last Post: 06-11-2011, 08:54 AM
  3. What do you guys think?
    By Geeto67 in forum General
    Last Post: 03-19-2011, 05:20 PM
  4. hey you FCB guys
    By bfd in forum Parts For Sale
    Last Post: 01-11-2011, 06:05 PM
  5. what do you guys think
    By speeds in forum General
    Last Post: 03-25-2007, 07:26 PM
