Thoughts on a 35mm fork upgrade
This is a discussion on Thoughts on a 35mm fork upgrade within the General forums, part of the Caferacer.net Forums category; So I think I'm wanting to get rid of the OEM 1975 Honda boatanchor forks. I'd kinda like to stick with 35mm so I don't ...
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 35
    Aug 2006
    Portland, Oregon, USA.
    So I think I'm wanting to get rid of the OEM 1975 Honda boatanchor forks. I'd kinda like to stick with 35mm so I don't have to worry about swapping triples though ultimately I could machine new ones to suit any fork I want I suppose.
    However, is there a relatively modern (lighter and prehaps cartridge style) 35mm fork option out there? I can adapt cartridge emulators to my existing pogo-sticks but they'd still be massively heavy and I'd like to continue shaving flab off this porky bitch.
    So...anyone have any insights?
    ~Albert Einstein
    first gen ex500s are 36mm. just a thought. The spacing may be off.
    Aug 2006
    I can bore an extra millimeter out of my existing triples. That's a thought for certain.
    ~Albert Einstein
    Moderator jbranson's Avatar
    Feb 2004
    , , South Sandwich Islan.
    Why not VFR250 forks....they are 35mm?
    Also they are air forks...have an air fitting on the top.
    somewhere on the web is a fork seal application guide. This will tell you what bikes have 35mm tubes. It won't give you any other dimensions but it is a start.
    buckandaquarter's Avatar
    Sep 2008
    Yeah but VTR250s have wierd inboard cast iron brake disks.
    http://www.chopperfix.com/forums/vie...c0c9caa34740f7
    Fork tube diameters are near the bottom. I think it would be easier to swap the triples, which this guide will help you do because it has all the upper and lower bearing dimensions listed as well.
    Senior Member oldhondacafe's Avatar
    Mar 2009
    Riverside, Ca., USA.
    I dont know what modle Honda you have, but you might look at early CBR600s. the spindle on the lower triple clamp uses the same dia. bearings as most Hondas with 35mm forks, and they have cartridge valves. They are lighter weight too. I have a '75 CB500t, I put CB400f fork on it they fit. you have to shim the bearing a bit and chang the steering stops. The CBR600 also has a 20mm axle so unles you like those Disco looking alloy wheels, you have co change the bearings in a spoke wheel. THe CB500t wheel is the same wheel as many mid sized Honda from this era, I bought new CBR600 WHeel bearings and they fit. these bearings are sealed so I just reamed the seal on the bearing retainer nut to 20mm and cut a piece of pipe to use as a spacer between the bearings
    \'78CB750f,\'76 cb500t,\'5-CB/CL450 basketcases,\'68 CL175,\'66 CA77/in a CL72 frame,\'1971 DT1f,1988cbr1000f,1987cbr1000f
    Mar 2009
    There is a CBR600 front fork and triple clamp on E-bay for $60. + $18. shipping. There's a lot of CBR parts out there, cheap, and it's 20 years better technology, it's usualy lighter and stronger, and still suported by aftermarket suppliers. also it look cool.
    Senior Member Mr Fischer's Avatar
    Sep 2008
    Hanover, PA, USA.
    I used the forks off a GS 750 (I dont remember the year) They were 35mm and worked great with the CB triples .They had an anti dive thing on the front. I had to machine the caliper mounting lugs to get the calipers to fit the discs (CB 550). I had to drop the forks(inner spacer) to get rid of the 3 inches that was originally above the top tree.
    I probably did more mods to get them to work with the CB wheel, but it was years ago and I dont remember the details.
    DG
    Quote from Vanna White
    http://i111.photobucket.com/albums/n...VannaWhite.jpg
    Fishhead Big Brakes
    http://s111.photobucket.com/albums/n130/dgfischer/Fishhead%20Big%20BRakes/?albumview=slideshow
    Aug 2006
    Good info all 'round.
    I have a fairly well stocked wrecker 5 miles from my shop and another REALLY well stocked one 25miles or so away. I think I'll go poke around and see what I can come up with but I'm now leaning away from 35mm and may even consider USDs if I can find a good deal on a pair of straight ones.....I think finding them straight may be difficult but I dunno for sure.
    In any case I think I'll just hog out some new triples unless something OEM really sticks out whilst in-situ....
    ~Albert Einstein
  1. CB750 Custom Fork Upgrade
    By domel in forum General
    Last Post: 03-20-2011, 01:47 PM
  2. how important to upgrade to 35mm forks?
    By freedomgli in forum Vintage Motorcycle Racing
    Last Post: 10-12-2009, 10:39 PM
  3. thoughts on carb upgrade
    By pampadori in forum General
    Last Post: 03-10-2008, 03:58 PM
  4. 35mm ceriani fork ears on ebay
    By snorkelfork in forum General
    Last Post: 11-29-2007, 10:15 AM
  5. 35mm fork options???
    By robertob in forum Technical
    Last Post: 10-21-2006, 10:42 PM
35mm forks and triple clamps ebay
35mm inverted fork
cartridge for 35mm forks
