Hacksaw Welding
Hacksaw Welding
This is a discussion on Hacksaw Welding within the General forums, part of the Caferacer.net Forums category; Hi Gents: I asked a few questions over here about welding up an exhaust https://www.caferacer.net/forums/topi...TOPIC_ID=10670 Hack was kind enough to answer, but his posts are ...
Results 1 to 10 of 15
Thread: Hacksaw Welding
    chrisf's Avatar
    Hacksaw Welding
    Hi Gents:
    Hack was kind enough to answer, but his posts are somewhat cryptic...unless you really know the subject. So rather than screw around asking questions, I just called the guy. I learned more in 15 minutes than I could posting for weeks. So here is the result:
    First, Hack told me to learn to weld razor blades together. I did these with a 3/32" electrode.
    Kidding, I used a .040" electrode, which was too big for the job. Eventually I got it.
    Here is the back. My six- year old told me it was Play Dough, but it was something else that melted to goo.
    Then I tried my hand at fusion welding 16ga 304 stainless. This is my first go at it, and I had to cheat with some filler in a couple places.
    Here is the second go at it. I had to use filler to get the puddle going, then I didn't need it. No back purging because I rarely got full penetration.
    Then I had a go at building some mild steel primaries. I fusion-welded these too, then put a tiny rosette on the inside. These look a lot better than my originals. I hope they are strong enough for the job.
    Much better than the first try. For reference, here is the set-up I used on the primaries:
    10cfm
    50 amps at the machine
    5 seconds post-flow
    .040" electrode
    gas lense
    1/4" opening
    Feedback is always appreciated.
    --Thanks for looking, Chris
    Jun 2008
    Medford, Oregon, USA.
    next weld soda can together and you'll be set. That looks pretty good to me. Though everything looks better then fluxcore madness with all the crazy herpes looking splatter leftover to grind off. lol.
    , Decrepit and Decomposing, .
    much better and I enjoyed talking with you
    call anytime or if you are ever in my hood
    come hang and we'll probably both learn something
    even without a lathe, you could prep those sleeves with a tiny step using maybe a hand grinder/wizz wheel clamped down and your sleeve tubing loosely clamped in a vice
    rotate by hand and end up with a 70ish thou step so you could make a really nice and easy autogenous bead on the other side
    the shiny beaded butt joint is much closer and you can see that making sure everything is clean prior makes life better
    after brushing it with non-contaminated media (stainless brush or sanding disc... I prefer no sanding or grinding carbides to worry with) wipe it with acetone then weld
    if you can make it puddle with less heat and keep the torch head angle consistent as you rotate around your tubing
    you can get that correct color, get your nearly 100% penetration
    and the bead will be nearly flat
    go back and reference the part about electrode stick out and "walking the cup"
    I set up to walk the cup anytime I'm able and that is why I seldom spend extra for the gas lenses... they don't suffer the heat from walking the cup very well
    or maybe they have ones that do now
    practice some more, you still need it, and get the feel for it
    do some more blades so that the bead is rounded on the top instead of over-penetrating like the ones shown.... less heat and narrower bead
    very good that you got them stuck together
    I think you'll do very well
    did you try turning down or off the high freq starting? not sure if your machine can adjust both starting freq and current or just current but keep playing with what it has
    if your machine isn't fine enough you may have better results touch starting it off to one side if it wants to blow holes right off the bat
    I'm thinking that may be the case as getting the puddle going without filler should be the easiest part of the deal providing everything is clean and well fitted
    50 amps on my machine would destroy that stainless
    find the least amount needed, dial in ten or twenty percent more and use that pedal
    and btw... you want that same chrome looking bead on the sleeve welds too
    you don't want gray at all but looks like you'll have it going your way soon
    never mind on the gray sleeve welds, I looked again and can see they are not stainless and are only a little too warm for mild
    could be this monitor and their color really may be perfect
    close enough
    and you may also find a better feel seeing how low you can go with the flow
    with stuff like that I use 10 or less without a gas lens
    and a gas lens requires less flow
    it may tend to reduce start up blowing thru
    not sure if there is any science to that, probably some, or if it's psychological
    but in any event, you want to know what the least amount of flow you can have and still carry the arc
    even if you go a bit higher just for good measure
    chrisf's Avatar
    Hack:
    After a small coversation, I feel like I progressed very far. I'll call again about aluminum.
    I forgot to say I welded a bit of Ti. I hade some 22ga scrap in the bin. I started a puddle and moved it around the tube. Ti actually welds the best of all the materials I've tried. I didn't back-purge, and the puddle as very porous on the backside. Still, fun stuff.
    You want the [u]inside</u> of the sleeve to have a bevel? I can do that with a die grinder and sanding wheel. Good idea.
    I'm picking up another box of blades today to practice some more. I do think I need a .020 electrode because it is difficult to establish and maintain an arc at those low amps.
    I forgot about your advice on turning down the start temp. I'll do that today.
    My regulator loses accuracy below 10CFM. I have two ball-type regulators on order. Those should be here this week.
    Amps...Yeah, I was barely into the pedal. I think I will try turning it down today--just to see how it performs.
    Thanks for all the advice.
    --Chris
    chrisf's Avatar
    Pinche:
    I have no idea how people weld soda cans together. Hopefully, one day I can try it.
    --Thanks, Chris
    come by and I'll give you a flow meter that is accurate at 1cfm
    gas lenses really don't require so much flow and you will find better luck with that razor joint with less flow
    good gvt surplus stuff
    ventilate well when welding ti and for real deal ti welding... not purging is never an option regardless of the joint
    I've been sick twice in the last ten years and both times were from welding ti without enough ventilation
    it will flat out put you down in the bed hard
    not a bevel on the sleeve.... a step which you will use as roughly a square piece of 70 thou filler
    when you make the joint with a flat bead
    it will then be beveled from the sleeve to the pipe
    you are doing fantastic and when you get ready
    I probably can help you get on your way to welding aluminum foil or beer cans together
    Mar 2006
    south Orange County, CA, USA.
    HackA can weld steel wool. Little known fact.
    Mar 2004
    Raymond, NH, USA.
    Remind me to never post pictures of my flux core welding...
  1. Aluminum welding
    By Kurlon in forum Technical
    Last Post: 08-01-2011, 12:58 AM
  2. Welding and custom fab.
    By erichsmith in forum Member Products
    Last Post: 09-10-2010, 10:05 PM
  3. Welding
    By tonupoakland in forum General
    Last Post: 07-27-2009, 07:47 PM
  4. welding?
    By ross_mc in forum General
    Last Post: 11-26-2007, 01:47 AM
  5. Tig welding/ machining
    By ROSKO in forum General
    Last Post: 03-18-2005, 02:40 PM
