Cb 450 K5 right side case?
This is a discussion on Cb 450 K5 right side case? within the Parts For Sale forums, part of the Classifieds category; Anyone? IMSLOW- if you happen upon it drop me a line. I'll throw you some loot for the hassle and shippin' Or if you find ...
Results 1 to 10 of 14
    Moderator ROSKO's Avatar
    Feb 2005
    Anyone?
    IMSLOW- if you happen upon it drop me a line. I'll throw you some loot for the hassle and shippin' Or if you find anything else.........Thanks again.
    BORN TO LURK, FORCED TO WORK.
    Moderator imslow's Avatar
    Apr 2003
    , Maine, .
    i have it somewhere. I'll take a look soon.
    s
    Feb 2005
    THANKS!
    The project is coming along, run into my first problems but, so far, so good.Everything is in really good shape! Stripped it all down and prepping the frame for welding....
    I can't thank you enough... Did the wife evr notice the extra space?
    If you find anything drop me a line and I'll send some dough for shipping. If not, I'll find one elsewhere.
    Anyone have any suggestions for a remedy/replacement of the sht singlepuck front brake?
    Member Brentadour's Avatar
    Nov 2002
    West Chester, PA, USA.
    I have a complete motor. I don't know what year.
    Apr 2003
    , Maine, .
    I'' find it this weekend, i promise.
    s
    Feb 2005
    No rush, I'm away for 2-3 more weeks. If/ when you find it(or anything else) drop me a line and I'll paypal you some $$$ for shipping. Thanks again.
    Rosko,
    About that POS front brake: A really good cleaning up and replacement pads makes a big difference. When I was racing my 400f (same POS brake) I made sure that the pivot pin was cleaned and lubed up so that it would easily move without any resistance. I really cleaned the cylinder bore and the piston so that it moved easily and cleaned all the gunk out from behind the piston o-ring. If there was a dust seal on the piston, I removed it since it seemed to trap moisture and gunk in the caliper. Then I removed the adjuster screw and spring and let the caliper self center. If I kept it cleaned and m,aintained after that, it was pretty good. One of the problems with that caliper design is that the pads will wear unevenly and become tapered. They need to be replaced at that point. The other problem is that the pads, especially the stock ones, is that they seem to get glazed in a hurry. I regularly scuffed them up with some sand paper. They were racable but there are other later model dual piston setups that can be made to work but not without changing front fork sliders and wheels and such. Try cleaning up the original brake and seeing if you need more.
    AHRMA 412
    Feb 2005
    Wow, so much activity whilst I'm gone!
    IMSLOW- just let me know...
    BRENT- I'd love an extra motor for parts if you're offering....
    kenessex- That is my first project upon return. See what an overhaul/ rebuild does and take it from there.
    JD
    JD is offline
    Senior Member JD's Avatar
    Mar 2002
    NY
    on the honda disk brake...they aren't that great. however, on my 350f racebike I had braided lines and good ferodo pads from Vintage Brake and it really worked a helluva lot better than stock.
    Senior Member Camelhairy's Avatar
    Sep 2005
    Chester, NH, USA.
    I have a CB450 that I think is a 73. It's not complete but you can have it if you take all that's there.
    FrankC
  1. best case for ipad
    By n/a in forum Wanted
    Last Post: 09-26-2012, 02:48 AM
  2. Battery + Case
    Last Post: 08-31-2011, 04:22 PM
  3. clearly a case of ebay bid padding....
    By ROSKO in forum Bikes For Sale
    Last Post: 01-21-2008, 09:14 PM
  4. Into the crank case it goes...
    By savor in forum Technical
    Last Post: 10-22-2006, 01:48 PM
  5. In case your looking for a new truck..
    By A.D. in forum General
    Last Post: 02-07-2006, 08:59 AM
