Fork upgrade - Page 3
Fork upgrade
This is a discussion on Fork upgrade within the Parts For Sale forums, part of the Classifieds category; naw, I pushed it as hard as I could on a frame I built. I've ridden bikes with unmodified stock frames and usd front ends ...
Results 21 to 30 of 40
Like Tree5Likes
Thread: Fork upgrade
  1. #21
    Sep 2008
    Rochester, New York, USA.
    naw, I pushed it as hard as I could on a frame I built. I've ridden bikes with unmodified stock frames and usd front ends and the stopping ability is markedly better than they were. hey, how come my post about swapping a gs650 crank into a gs550 bottom end didn't get any replies? guess this has become a haven for craggy old guys. ok ok I'll get off yer lawn
  2. #22
    naw, I pushed it as hard as I could on a frame I built. ....
    I totally believe that.
  3. #23
    this part is just dumb.
    ... do you honestly think that is what was in question
    woodsman likes this.
    Senior Member Teazer's Avatar
    Mar 2010
    , IL, .
    how did this thread end up in the dumpster. The issue raised, though not very clearly, was that USD forks are usually shorter than stock old school forks and that fitting them to an old bike could very well cause handling, braking and safety to deteriorate.
    Next point was that fitting modern forks with a modern 3.0" or 3.5" front 17" wheel would look a little odd on a bike with a 2.15" rear rim and on a shaft drive bike that isn't an easy problem to fix for most people.
    Admittedly, some of the comments are framed in less than helpful terms, but this site tends to be a bit like that.
    As for me, I have lowered, lengthened, shortened and raised bikes and in one case I have tried all the above on the same bike... I have fitted USD forks and monoshock rear ends to old bikes and braced the frames and although they will never beat a modern bike around a corner, they are better than stock IMHO. And I tend to reduce engine width if I lower the motor to avoid levering a wheel off the deck when cornering on the way to get coffee.
    All that said, if I had a GS850, I would be wary of fitting modern suspension and wheels and would probably try a less radical approach to improving brakes and handling. Relatively modern calipers can be fitted and if it needed stiffer forks, a set of larger diameter GS1100 forks would probably drop straight it with little modification. There are ways to improve the looks and performance of that bike, but it's not the most suitable place to start to build a radical cafe racer.
    If that's what you have, think in terms of suitable changes and forget what you see on pipeburn and other sites for art projects.
    CaTacL1sm likes this.
  6. #25
    Quote Originally Posted by Pete82 View Post
    Hi, I have a 1982 GS850gl. I'd like to upgrade my fork suspension to something more modern like the inverted ones. anyone know what would fit my GS?
    I'm going to just answer his question....
    First generation GSXR1100 USD forks are the longest you will find (91-94, I think). That's probably your biggest concern as in getting the longest ones to maintain your ground clearance. They also run the same steering head bearings so the swap is as easy as it will get if you get an entire front end.
    The only problem will be they are over 25 years old and not that easy to find anymore.
  7. #26
    jcw
    jcw is offline
    Senior Member jcw's Avatar
    Jul 2015
    chicago burbs
    Shorter forks can occasionally be lengthened safely or paired with custom drop triples, stock rims can be spaced on the front axle with new bearings and spacers or a custom axle. Rear rims can be widened if you have $$$ burning a hole in your pocket.
    But, I think the stiffer structure just is a poor match for the rest of a 70's and early 80's cradle frame unless it comes with additional modifications.
    Nothing wrong with pointing that out to people.
    - - - Updated - - -
    IThey also run the same steering head bearings so the swap is as easy as it will get if you get an entire front end.
    Don't forget the stem length...
  8. #27
    kijiji has a listing for a 1988 gsxr1100 complete rolling chassis minus the motor, even has ownership papers, 1000$ Canadian, located in Toronto.
    https://www.kijiji.ca/v-sport-bikes/...100/1371027198
    front end certainly looks massive enough, should only add a few pounds
  9. #28
    I kinda agree....and not.
    I mean, how is using a stiffer fork a liability? If you put a fork brace on a conventional fork it's an "upgrade", right?.....replace the shitty sagged stock springs with new ones and that's an upgrade too....
    I understand how the thought process is here with the stiffer forks highlighting the shortcomings of the chassis, but that's where you start frame bracing and modifying other components if you are serious about it.
  10. #29
    Why wouldn't you just use the whole rolling chassis and shoehorn the wrong motor into it
    :I did that, when I was ~14 years old.
  11. #30
    jcw
    jcw is offline
    Jul 2015
    chicago burbs
    If that is the plan then have at it! But I don't see most people asking about fork swaps having the knowledge or ability or even the desire to brace a frame to the extent of making a difference.
    I see what you mean, but I'm thinking you are running into the area of rapidly diminishing returns, and the USD forks are at the far extreme given the price of some of these front end conversions.
    They remind me of wings and spoilers and trash can sized exhausts on those japanese 4 bangers. All show...
  1. 79 CB750K Fork and Brake upgrade options
    By JDsCB750K in forum Technical
    Last Post: 04-08-2015, 12:17 PM
  2. CB750K7 (1977) twin disc/fork upgrade
    By Doctor Jones in forum General
    Last Post: 11-19-2013, 07:54 PM
  3. CB750 Custom Fork Upgrade
    By domel in forum General
    Last Post: 03-20-2011, 01:47 PM
  4. Thoughts on a 35mm fork upgrade
    By Swagger in forum General
    Last Post: 09-08-2009, 02:13 PM
  5. Fork Old Bikes ...fork you all!!
    By LiLBull in forum General
    Last Post: 04-28-2007, 08:59 AM
