My Suzuki GS550 build
This is a discussion on My Suzuki GS550 build within the Project Builds forums, part of the Caferacer.net Forums category; I cobbled this bike together and it ran ok...but I've decided to strip it down before the winter and have it back together by Spring. ...
Results 1 to 7 of 7
    martyman's Avatar
    I cobbled this bike together and it ran ok...but I've decided to strip it down before the winter and have it back together by Spring. My main concern is the Stock triple tree raises the bars up high and I'm trying to figure out how to change them and not have to change all the cables...
    martyman's Avatar
    Stripped the bike down to the frame yesterday....bagged and tagged everything or put the original bolts back where the were from so I don't mix them up. I wouldn't do this in the past and it made the job of putting stuff back together impossible. I'm going old school and going to find a vintage headlight/speedo/tach...I also need to find a triple tree that will fit the original forks.
    martyman's Avatar
    I washed down the frame and swing arm with dish soap/sponge today and gave it a coat of paint today...turned out nice, no runs at all.
    caffrcr's Avatar
    Sep 2009
    good job painting, looks good man
    martyman's Avatar
    Put the motor back in yesterday...it was a tough one by myself but I did it...
    Nov 2008
    That's a GSX550, 16 valve.
    quite nice motor, can be revved a lot higher than the roller bearing crank model it replaced without blowing big ends.
    Shit electrics though.
    You will probably need a regulator/rectifier, get one off a CB/CM400, much more reliable.
    When generator stator fails either get GS1000 or have original rewound (don't mess about with any form of 'genuine' replacement, it will just do same as original)
    Same carbs as Kawasaki KZ1300
    PJ
    martyman's Avatar
    Same carbs as a Kawi 1300? (I'm assuming there are three carbs from what I see on ebay) mine has two really? can you tell me what year? thanks for the info...most of the electrical components have been changed on this bike by the previous owner.
  1. 81 suzuki GS550 cafe racer
    By TheKillerSN95 in forum Project Builds
    Last Post: 08-30-2012, 08:31 PM
  2. GS550/650/750 Build
    By roccitycafe in forum Project Builds
    Last Post: 02-28-2012, 05:36 PM
  3. Wanted: Parts for 1978 Suzuki GS550
    By AllStatus in forum Wanted
    Last Post: 01-15-2012, 12:55 PM
  4. Just got a 1977 Suzuki Gs550 - without title ???
    By anup_vince in forum General
    Last Post: 03-01-2009, 04:40 PM
  5. First Project 1978 Suzuki GS550
    By Athena in forum Project Builds
    Last Post: 05-15-2008, 10:48 PM
1977 suzuki gs550 forum
