Bultaco Metralla
Bultaco Metralla
This is a discussion on Bultaco Metralla within the Project Builds forums, part of the Caferacer.net Forums category; So I got this Metralla from an old man's shed: https://www.caferacer.net/forum/topic...38&whichpage=2 and I plan on cafe-ing it. Lots of parts missing so I'll sell the ...
Page 1 of 5 123 ... LastLast
Results 1 to 10 of 42
    Senior Member robertob's Avatar
    Aug 2006
    Long Beach, Ca, USA.
    Bultaco Metralla
    and I plan on cafe-ing it. Lots of parts missing so I'll sell the few remaining original parts on ebay to fund the racy parts I need.
    Right now all I have is the frame & wheels and a Pursang MK4 motocross engine. Original Metralla motor disappeared a long time before I came around.
    I'll be adding a Circle F pipe, Powerdynamo ignition, ported cylinder & re-machined head.
    Forks will be 35mm Betors from a Sherpa T, shortened, with emulators and .75 kg/mm springs. I'm working on those right now.
    Aug 2006
    The Sherpa had a 12mm axle so I had to buy a $30 15mm reamer to fix that little problem. Also had to press out the Metralla steering stem and press it into the Sherpa triple clamp. Then I had to shorten the Sherpa forks - I just put a spacer on the damper rod made from PVC. That reduces the travel but actually the Sherpa forks had 1 inch more travel than the Metralla forks to begin with. The Met forks are actually pretty cool - they have a cartridge in them for damping. But it's still a simple damper and the emulator (one of the MikesXS taiwanese ones) will provide better compression damping than the stock ones ever could. Plus the 35mm forks look better and flex less. And it's easier to find clip ons and headlight brackets for them.
    Otherwise it's a bolt on deal. Well, there is the small matter of needing spacers on the front brake link, but I've seen pictures of TSS roadracers that used similar spacers.
    Senior Member santa_ana's Avatar
    Jul 2010
    Fuengirola, Andalucia, Spain.
    Them betor forks are nice, summer 09 i used my `78 Sherpa T350 almost every day to go around town, about 2500kms and apart from a snapped clutchcable zero problems. Suspension on it works so good, makes you forget that its over 30 years old. I love it! Lil pic:
    Chris
    Jul 2010
    Chris
    Senior Member Teazer's Avatar
    Mar 2010
    , IL, .
    Nice find. Many years ago I ran an Ossa SDR complete with knobby tires on the street as my only transportation. It was so much fun.
    Are you thinking TSS replica or America Kit style? Either would awesome. My own preference is the tank and seat from the water cooled model because they look lower and more together. Keep posting. I'll be watching this one.
    Mar 2010
    , IL, .
    Mar 2004
    Raymond, NH, USA.
    Keep us up to date on how the Powerdynamo ignition works. I'm interested in their ignitions.
    Mar 2004
    Raymond, NH, USA.
    Aug 2006
    I'm thinking TSS 350 - it has the seat that bumps up at the back. There's also an Endurance model with a cool headlight, I'll see if I can find a picture.
    As for the 35mm betors - they are really sophisticated forks. Much nicer than Honda stuff from the 70s. They have a vented cap and a long hydraulic stop at the end to bottom more positively than air pressure would do. Plus there is a one-way valve that prevents leaks through the compression holes during rebound damping. And a proper hydraulic piston on the damper rod. Pretty cool stuff for the 1960s.
    I have some .70 springs on order.
    Aug 2006
  1. bultaco metralla
    By p1j in forum Project Builds
    Last Post: 11-23-2011, 10:56 AM
  2. Bultaco Metralla
    By robertob in forum General
    Last Post: 11-18-2010, 09:22 PM
  3. WANTED PRE 1969 BULTACO METRALLA
    By hondapro171 in forum Wanted
    Last Post: 02-11-2010, 12:00 PM
  4. 1970 Bultaco Metralla - Indianapolis - $4300
    By gram in forum Bikes For Sale
    Last Post: 03-23-2009, 03:15 PM
  5. Bultaco Metralla
    By clutchkith in forum Bikes For Sale
    Last Post: 01-03-2009, 04:42 PM
* is my favorite seat *
bultaco cafe racer
bultaco metralla
bultaco metralla for sale
bultaco metralla for sale australia
bultaco metralla parts
bultaco tss parts for sale
parts for metralla front forks
used bultaco metralla sale
