progress on my cb350 today
This is a discussion on progress on my cb350 today within the Project Builds forums, part of the Caferacer.net Forums category; I've made some progress today on my cb350. fitted a cb400f gas tank using suzuki gs front mount and stock cb350 rear mount relocated.I welded ...
Results 1 to 9 of 9
    Senior Member kochic's Avatar
    Feb 2011
    st-jean-de-matha, QC, Canada.
    fitted a cb400f gas tank using suzuki gs front mount and stock cb350 rear mount relocated.I welded a cb350 lookalike rear bracket to the cb400 tank.
    I installed tapered streering brg too.i still have to figure out the top nut.They give some instruction in the allballs kit to modify the stock nut.
    for the rear cowl i use a suzuki GK rear tail and narrowed it 2 1/4 in.I only made a couples of "spotweld" for the mockup.The tank and seat are rubbers mounted.
    Here are some pics.
    marc
    honda cb350 1973
    suzuki gs1000 1978
    Senior Member cafe350's Avatar
    Mar 2009
    Columbus, OH, Djibouti.
    Cool. Looking forward to seeing how the cowl turns out. I don't recall having to modify anything to fit the AllBalls kit though, should just be a matter of fitting the correct spacer.
    \"Hey, McCloud! Get off of my ewe!\"
    Trevor,
    \'72 Honda cl350 (sold)
    \'80 gs450E, the \"spooky \'Zuki\"
    \'04 Kawasaki Ninja 500
    Senior Member oldhondacafe's Avatar
    Mar 2009
    Riverside, Ca., USA.
    That tail piece looks pretty good, did you "spot weld" it with heat? I am courious about repairing those plastic parts, do you know how to do a more perminant repair on it? I'd like to see about that. I think the suzuki tail is a good match for that tank, I'm looking forward to seeing how it comes out. keep up the good work!
    \'78CB750f,\'76 cb500t,\'5-CB/CL450 basketcases,\'68 CL175,\'66 CA77/in a CL72 frame,\'1971 DT1f,1988cbr1000f,1987cbr1000f
    Feb 2011
    thanks,
    I just milled the flange inside the top nut.I have to do this to put preload to the inner race of the top bearing.
    I welded the seam with a small pencil type soldering iron.I made a pass on the 2 sides.Its been years that i use this method and this is a permanent repair.I have to fill the exterior with bondo on the weld.I will post pic of the tail welded.I have removed the indent for the rear reflectors too.
    Marc
    honda cb350 1973
    suzuki gs1000 1978
    Feb 2011
    Plastic welding all done, just need the bondo and a sanding.
    Marc
    honda cb350 1973
    suzuki gs1000 1978
    Feb 2011
    I laced(but still have to trued) a NOS did wm3 X18" to a t500 hub.
    I welded a fitting on the torque arm for the rear brake cable.
    I will have to find-buyor make a baffle like this one.
    Marc
    honda cb350 1973
    suzuki gs1000 1978
    Fairfax, VA, USA.
    Any updates?
    Fairfax, VA, USA.
    Any updates?
    Feb 2011
    Yes,
    The projct is slower than my liking,
    My front end is sorted, only have to buy spokes and new fork tubes.
    I have cb500 forks with kawasaki gpz550 triple tree(35mm with 4 lower pintch bolts) and a gt750 brake + a tannermatic fender.
    I will post a couples of pic.
    I havent touched the bike for at least 6 months.
    Marc
    honda cb350 1973
    suzuki gs1000 1978
  1. took the CB350 out for the first time today
    By TheGreg in forum General
    Last Post: 09-29-2010, 03:05 PM
  2. Hey hack, I drag raced my cb350 today
    By Mercury Kid in forum General
    Last Post: 03-17-2010, 08:55 AM
  3. progress on the 750 so far
    By speeds in forum General
    Last Post: 09-29-2007, 04:48 PM
  4. Progress
    By mikeinnh in forum General
    Last Post: 01-14-2007, 09:00 PM
  5. CB350 Cafe Racer in progress
    By Rob Lloyd in forum General
    Last Post: 07-01-2004, 08:22 AM
cb350 suzuki tank
suzuki cowl on honda cb350
