honda 350
honda 350
This is a discussion on honda 350 within the Project Builds forums, part of the Caferacer.net Forums category; i wish we had the option to completely delete old/redundant threads...i'm catching some heat for maybe getting rid of a bit of useful info. wasn't ...
Page 1 of 7 123 ... LastLast
Results 1 to 10 of 65
Thread: honda 350
    Senior Member jackshite's Avatar
    Jul 2009
    Austin, Texas, USA.
    honda 350
    i wish we had the option to completely delete old/redundant threads...i'm catching some heat for maybe getting rid of a bit of useful info. wasn't my intention, just felt like it was covered better elsewhere.
    that being said, here's the new build thread.
    a lot of time has passed since i started this little project. i've learned a lot and hopefully it will translate to the end result.
    originally this was a '72 cb350k4 that i spent a lot of time and money on. engine trouble (bits of rubber and metal in the oil) turned into a full disassembly, which turned into a full redo (cracked frame, etc.)
    i stockpiled a bunch of goodies for the bike, then reality hit in the form of a break-up with the girl, moving out, etc. i sold a bunch of stuff to get into a new place.
    fast forward to a couple months ago...
    a friend was getting rid of much of his 350 parts, so i was able to replace pretty much everything i'd sold last fall.
    this got the ball rolling on the project again. it's got so much different stuff on it now, it's not really a cb, hence "honda 350".
    here's where i'm at right now:
    replacement cb frame was found (late '71 build date), cleaned up and modified. boxed seat rails, ground and welded all seams, installed rear loop and underseat battery tray.
    aftermarket fender cut and mounted. seat pan made.
    early cb front end with NOS 70's aluminum fork brace, cl450 front wheel.
    stock cb350 rear wheel. (in fact, the only parts left from the original bike are the swingarm, rear wheel, and footpeg bracket/kickstand)
    wheel bearings/seals were checked, cleaned/greased, new brake shoes, new dunlop k70's. new swingarm bushings.
    all chrome and aluminum parts have been blasted/scotch-brited to a 'brushed' finish (rims, fender/bars, fork tubes, etc.)
    engine is an SL bottom end (second gen, minus e-start), modded cb top...honed cylinders (stock bore), new rings, tsubaki HD cam chain, KA tensioner, intake and exhaust ports cleaned-up/matched, valve job, type-1 cam/followers, HD clutch springs, rick's uprated stator/rect/reg, boretech elec ignition, dyna mini-coils, vm30's/k&n filters/cb360 intakes. still need to make the exhaust (stainless 2-1).
    just finished top-end assembly this past weekend. we have a dyno at my roomie's shop, so it'll be tuned and we'll see where it's at asap.
    yet to do: figure out seat mount, clean up a few welds, then frame/swingarm/etc. is ready for paint. tank will be de-rusted and painted in the next couple weeks.
    still have a few bits to get: ass't hardware, cable adjuster for brake lever, seat foamed and cover made, headlight and mounting, tail light...
    some pics:
    as it sits from this past weekend
    getting the top end on and cam chain together
    first attempt at a seat pan, made from scrap from work
    it fits
    forgive the mess and clutter, we literally have no room in the garage with both roomies' racebikes and projects.
    more as i get it done...
    Moderator imslow's Avatar
    Apr 2003
    , Maine, .
    Does the SL motor fit in a CB frame? I have an SL frame with a SL engine, and didn't think it would work. Just curious if you had tried mounting the engine yet.
    Inertial dynos just make people cranky
    Senior Member catboy's Avatar
    Aug 2006
    Detroit Metroplex, MI, USA.
    so glad to see you back at it, j!
    cheers!
    iphone generated fag
    Nov 2008
    Your Moms House, USA
    Pretty sure they fit.
    Jan 2008
    Southern Finland
    please tell me that it is more of a tracker than a "brat" bike. I tired of those.
    And it is looking great!
    Jul 2009
    Austin, Texas, USA.
    my friend i got the engine from told me the right lower mount (as you sit on the bike) would have to be relocated, so i cut it off without checking.
    when it came time to weld the mount in place, we found that if it was relocated, it was only by a very small amount. i haven't checked the top mounts, but the bottom ones are all pretty much stock. YMMV.
    Jul 2009
    Austin, Texas, USA.
    thanks.
    although it has a brat/gravel crew/wrenchmonkees influence, the biggest inspiration is this bike from japan (not sure of the builder):
    minus the scrambler pipes and rearsets, that's pretty much how it should end up. similar color, too.
    Jul 2009
    Austin, Texas, USA.
    cylinder head is back off to mill further. cam chain tensioner is getting stuck when everything is torqued down.
    off to roomie's shop to get it sorted, then back together. have to take the engine over to a local cycle shop to have the cam chain master link riveted. they have an old yamaha tool that looks like a bolt cutter.
    engine should be in frame by saturday. weekend wiring harness goodness. 100+ temps.
    Jan 2008
    Southern Finland
    speaking of wiring - you building a new harness?
    Any suggestions for good sources for wiring components. I need to do a harness from scratch and would like to use honda-style round connectors.
    Senior Member YucA's Avatar
    Jul 2010
    Miami, FL, USA.
    Not to thread jack, but...
    I pretty much did just that with the harness I built. OEM type connectors are f-crimp/open barrel so you need to make sure you have the right tool to crimp em. I got all the oem style wire I needed from Corey at lloydvintage.com. He's got the connectors as well, but I also found them a bit cheaper in bulk on these sites. They sell the tool also if you need it...
    Cheapest spot I found:
    http://www.vintageconnections.com/
    (check out their price list)
    Another option:
    http://www.oregonmotorcycleparts.com/connectors.html
    I think I posted a few pics of my harness on my build thread...
cb scrambler
cl350 scrambler brat
honda cb 350 cafe racer build list
honda cb350 points cover stripped threads
honda cb360 fork brace
k and w enterprizes fork brace
k&w enterprises fork brace
modifying cb360 sprocket covers
scrambler pipes
