how to lower a bike??
This is a discussion on how to lower a bike?? within the Project Builds forums, part of the Caferacer.net Forums category; Hey I just started my first build on a 74 honda cl360. I was wondering what is the appropriate measure that I should lower the ...
Page 1 of 7 123 ... LastLast
Results 1 to 10 of 69
    Junior Member oscarrico12's Avatar
    Sep 2011
    Fullerton, California, USA.
    Hey I just started my first build on a 74 honda cl360. I was wondering what is the appropriate measure that I should lower the front and the rear? I also would like to know how to do it (mainly the rear). thanks everyone!
    Sep 2008
    , , Mongolia.
    Let the air out of the tires, then put tie-down straps around the rear shocks and crank em as tight as you can. If your bike is still not stupid looking enough after all of that, you can put on clubmans and 59 stickers.
    Sep 2008
    , , Mongolia.
    Senior Member jaguar's Avatar
    Dec 2005
    Albany NY
    You did see that we have a search option here right?
    While you are at it search for our opinions on lowering a bike...remember this isn't some civic....
    If it's just a looks thing google " do the ton forum" they can help you on the looks thing
    Thanks and have a rad day
    I am Derby\'s Bitch
    Dec 2005
    Albany NY
    I am Derby\'s Bitch
    Mar 2006
    south Orange County, CA, USA.
    Hey, someone from OC! Welcome!
    Oscar, watch out for the cranky old dudes on this forum. They will jump on you for asking about modifications that do not improve performance. They are especially vigilant against suspension lowering, those meanies.
    Me? I just post friendly greetings and helpful advice, and I never criticise anyone's build plans. Go along and get along, that's my motto.
    Mar 2006
    Jan 2008
    Southern Finland
    Annnnd..... WHY?
    Its a pretty low bike - if you have issues putting your feet on the ground I would start t with the seat.
    Changing ride height will make your bike handle like poop. Especially lowering rear alone will make the attitude such that the rake is lower and handling slouchier.
    how?
    front, just a little bit can be done by sliding the forks in the clamps (1-2"). Doing more that way will risk hitting fender/tire into something.
    You can also take forks apart and shorten the springs + add a spacer of same amount.
    rear, get shorter shocks.
    Again - why?
    Jan 2008
    Southern Finland
    Annnnd..... WHY?
    how?
    Again - why?
    Sep 2011
    I do not understand why people go on forums hating, it is just a waste of time for both of us. thanks a lot to those who actually helped!
  1. Replacing Lower Crankcase on CB 350
    By themewsh in forum Technical
    Last Post: 11-20-2010, 04:15 AM
  2. how to inspect lower end
    By lovethosetwins in forum Technical
    Last Post: 08-16-2009, 12:11 PM
  3. Source for lower watt headlight
    By Johnny in forum Technical
    Last Post: 10-11-2007, 09:35 PM
  4. WTB: EX500 lower fairing (belly pan)
    By Wally Anderson in forum Vintage Motorcycle Racing
    Last Post: 04-24-2007, 07:21 PM
  5. WANTED: lower case for a '70 CB 450
    By ROSKO in forum Parts For Sale
    Last Post: 08-11-2005, 09:12 PM
can you lower a cafe racer
how to lower rear height cafe racer
how to lower suspenion on cl360
how to lower the front and rear of a cb360 cafe
riding on broken triple clamp cb360
