Budget Parts-Bin Bultaco - Page 28
This is a discussion on Budget Parts-Bin Bultaco within the Project Builds forums, part of the Caferacer.net Forums category; Originally Posted by Cyorg Is your bride wondering where her cutting board went? Nope. I bought big sheet of 3/16" HDPE about four years ago, ...
Page 28 of 42 FirstFirst ... 18262728293038 ... LastLast
Results 271 to 280 of 420
Like Tree59Likes
Thread: Budget Parts-Bin Bultaco
  1. #271
    Sep 2009
    Kansas City
    Nope. I bought big sheet of 3/16" HDPE about four years ago, plus some thick square blocks of the stuff, to use for just this sort of mock-up work. It's cheap, quick and easy to drill and cut, but rigid without cracking or folding easily.
    "With idiotic intentions come idiotic victories" – Salvage Bultaco franken-bike build log
  2. #272
    Sep 2009
    Kansas City
    So, I have my rear motor mount templates. I have 3/16" mild steel and 1/4" alloy stock; which of these should I make them from? Each arm extends 94mm from swing arm pivot center to bolt center.
  3. #273
    Senior Member Cyorg's Avatar
    May 2014
    Quote Originally Posted by Tanshanomi View Post
    I would use the 1/4 alloy. It's a bit of a span, but you are adding cross tubes (assuming that's still the plan), so should be good. My Triton plates are made from 1/4 "aluminium".
    Tanshanomi likes this.
    "Non urinat in ventum"
    Sep 2009
    Kansas City
    I put two pieces of stock together with split pins and commenced to cutting and filing. I'd gotten this far when I decided my bracket design is a bit thin. In 1/4" alloy, I'm afraid these would be a bit too willowy for all the mass I'll be asking them to support. I'm going to revise my design to make it a bit chunkier and start over.
  6. #275
    Jan 2015
    San Diego, CA
    Yea.......I also thought it would be good with the cross tubes.
    3/8?........
  7. #276
    Sep 2009
    Kansas City
    Quote Originally Posted by knappyfeet View Post
    3/8?........
    I'm going to stick with the 1/4" thickness, but make the pattern a bit more substantial:
    This gives a bit of scale, compared to the rubber engine mount:
  8. #277
    Senior Member Mark Burton's Avatar
    Jan 2014
    Midlands UK
    I made my alloy engine plates out of 3/8 inch plate and the original Triton plates where same as Cyorg says at 1/4". I sprayed some some quick drying silver paint - some galv weld through coating I had laying around, onto the plate to scribe out as it didn't tear up like paper or tape stuck on. Made it easier to file up afterwards.
    Stick at it
  9. #278
    Sep 2009
    Kansas City
    Shortly after I posted this, a friend of mine (my podcast co-host Garrett) offered to laser* cut my engine plates out of 3/16" steel. Since I don't have to fabricate them myself, I took the opportunity to make them a bit less plain. The only downside is the turnaround time is 2-3 weeks. I guess the interim gives me a chance to sort the wiring on the other project bike, which I've been putting off.
    *He said "laser cut," but I am guessing they'll actually be plasma or waterjet cut.
  10. #279
    Sep 2009
    Kansas City
    So, the laser cut (yes, really laser cut) rear engine mounting plates Garrett had made arrived yesterday. They're absolutely perfect. Here they are mocked up with some allthread. The bottom mounting stud will mount through the frame on both sides to take some of the load off the my skinny little swingarm pivot bolt. I will also have to play with spacers on each side of the pivot compensate for the thickness of the two plates.
    Obviously, I still have plenty of fabrication work to do here. I bought plenty of 1.25" x 0.120" wall DOM tubing and confirmed that the Suzuki GT rubber mounts are a properly snug push-fit. They will have small mounting tabs welded onto them, as shown in my original napkin sketch. The engine is slightly offset from the frame centerline. Rather than attempting to work out the exact engine offset ahead of time and then attempting to weld the tabs on in the exact correct location, I will place them further outboard from the engine mounting bosses and use alloy spacers to locate the engine into place between them. As long as the tabs are anywhere inboard of the chain run, I'm good.
    I also cranked up my lathe to make the fittings to connect the pieces of my new rear frame section to each other and the existing frame. I've finished one of the four.
    Two will have the same diameter on both sides, the other will be like this one, with a larger diameter on one side to fit the thinner wall tubing of the existing frame.
    Each one will fit between the two lengths of tube (ignore the crooked hacksaw cut, it's temporary)...
    And get welded around the circumference.
    CaTacL1sm likes this.
  11. #280
    Sep 2009
    Kansas City
    I mentioned this in passing early on, but one thing I am planning on doing is building a crossover shifter arrangement for a modern standard right-brake/left-shift arrangement. (I'm old enough that my neural net and premotor cortex don't adapt as easily.) I could find a late ('75-on) Bultaco lower end with the shift shaft exiting on both sides of the cases but, the "left side" shaft actually exits the cases directly inboard of the drive chain:
    As you can see, any sort of rearsets would still require some sort of goofy linkage around the chain run anyway. Besides, I already have earlier, right-shift-only cases and transmission parts. And finally, if I set it up with a crossover shaft, then I can put any Bultaco motor I want in it later, on the off chance the chassis ends up being something more than pure garbage when finished.
    Sooo... I'm currently thinking about how to incorporate a crossover shaft into that lower mounting location for the engine plates. The rubber mounts might complicate that, since they dictate the maximum diameter. For refernce, when I was at the British National Motorcycle Museum about five years ago, I took some photos of how a couple of later British bikes did the crossover thing:
  1. budget dunger (cbx750fe)
    By engel in forum General
    Last Post: 12-17-2011, 12:53 AM
  2. kz 440 cafe budget build
    By overthetop in forum Project Builds
    Last Post: 12-15-2011, 07:01 PM
  3. Bultaco Campera Parts
    By lastman in forum Wanted
    Last Post: 08-29-2010, 07:05 PM
  4. Building a low budget trike.
    By oneworden in forum General
    Last Post: 06-04-2010, 10:45 AM
  5. Budget Cafe CB350K-4
    By tshaw151 in forum Project Builds
    Last Post: 04-22-2010, 07:40 PM
atv shock spring compressor
atv shock spring compressor tool
atv spring compressor
building bultaco cafe racer
bultaco cafe racer
bultacocaferacer build
homemade atv shock spring compressor
homemade coil spring compressor
homemade spring compressor
