Budget Parts-Bin Bultaco - Page 39
This is a discussion on Budget Parts-Bin Bultaco within the Project Builds forums, part of the Caferacer.net Forums category; Surprise! I STILL haven't given up on this project. This morning before work, I dragged my frame jig and Bultakenstein's still-dead carcass out of the ...
Page 39 of 42 FirstFirst ... 293738394041 ... LastLast
Results 381 to 390 of 420
Like Tree59Likes
Thread: Budget Parts-Bin Bultaco
  1. #381
    Sep 2009
    Kansas City
    Surprise! I STILL haven't given up on this project. This morning before work, I dragged my frame jig and Bultakenstein's still-dead carcass out of the corners of the garage where they'd been a-molderin' untouched for the last year and a half. With the Honda CL125S Resto-mod that had been taking all my time and attention finally out of my workshop for good, I've turned my attention back to this unholy collection of mismatched parts.
    Picking up where I left off, the first step is to get the DT175 swingarm properly mated to the frame. The frame is now bolted in the jig true and level, and I just ordered some additional jig furniture from Chop Source that will help me accurately align the frame and swingarm.
    At least it is back out into the light prior to its eighth birthday, coming up just five weeks from now.
  2. #382
    Oct 2009
    Laredo, Texas
    Nice jig, dude.
    GrandPaul
    Author, \"Old Bikes\"
  3. #383
    Sep 2009
    Kansas City
    Rough removal of the stock footpeg mounts. I will use this part of the frame for additional jig attachment points. Eventually, the shift shaft crossover will mount between these bosses.
    Definitely needs more prettying up at some point, but okay for the time-being.
    Senior Member Teazer's Avatar
    Mar 2010
    , IL, .
    Make sure that the jig is absolutely level first - but I'm guessing you already knew that.
    I have that same set up and the floor has a few bumps and holes, so if I move it slightly when welding to get at it from a different angle, one foot can be high or low and that sends everything else out.
    edit:
    And don't assume that the stock swingarm holes or steering head are exactly square. They rarely are as they came out of the factory, let alone after years of (ab)use
  6. #385
    Sep 2009
    Kansas City
    Is a digital angle cube sufficient to true the jig components? That's what I've been using to check that everything is level and plumb.
    And once I got it level, I used a sharpie to draw little circles on the concrete around each of the feet.
  7. #386
    Sep 2009
    Kansas City
    Quote Originally Posted by Teazer View Post
    I definitely don't -- I've seen pictures of the Bultaco factory back in the day!
  8. #387
    Mar 2010
    , IL, .
    Quote Originally Posted by Tanshanomi View Post
    And a cube is good enough as long as it's calibrated (zero'd out) I use a cube more than my supposedly super accurate, silly expensive longacre digital
    Tanshanomi likes this.
  9. #388
    Senior Member Cyorg's Avatar
    May 2014
    How times have changed. I guess this and my angle gauge/blocks can now be used as door stops.
    Glad to see you dragged it out of the corner.
    "Non urinat in ventum"
  10. #389
    Sep 2009
    Kansas City
    Frame is bolted into the jig using the additional fittings, and I'm working on final alignment of the twin-shock swingarm:
  11. #390
    Sep 2009
    Kansas City
    I got two 6mm outer spacers made up this morning. The engine mounting plates need to be spaced in because of a pair socket-head screws that attach the support block on the left, as well as clear a bunch of big, globby welds on the inside of the frame on both sides. I still need one more 10.5 mm spacer inboard of the engine mounting plate on the left side. Unfortunately, I ran out of time. (For some reason, my employer doesn't seem to understand the vital nature of this project, and expects me to show up for work. Gaaah!)
  1. budget dunger (cbx750fe)
    By engel in forum General
    Last Post: 12-17-2011, 12:53 AM
  2. kz 440 cafe budget build
    By overthetop in forum Project Builds
    Last Post: 12-15-2011, 07:01 PM
  3. Bultaco Campera Parts
    By lastman in forum Wanted
    Last Post: 08-29-2010, 07:05 PM
  4. Building a low budget trike.
    By oneworden in forum General
    Last Post: 06-04-2010, 10:45 AM
  5. Budget Cafe CB350K-4
    By tshaw151 in forum Project Builds
    Last Post: 04-22-2010, 07:40 PM
atv shock spring compressor
atv shock spring compressor tool
atv spring compressor
building bultaco cafe racer
bultaco cafe racer
bultacocaferacer build
homemade atv shock spring compressor
homemade coil spring compressor
homemade spring compressor
