gs550 performance?
gs550 performance?
This is a discussion on gs550 performance? within the Project Builds forums, part of the Caferacer.net Forums category; I've got a customer who's looking to have a full fairing "GP" racer built, he's more concerned with the look, but wants a faster engine ...
Page 1 of 12 12311 ... LastLast
Results 1 to 10 of 118
    Sep 2008
    Rochester, New York, USA.
    gs550 performance?
    I've got a customer who's looking to have a full fairing "GP" racer built, he's more concerned with the look, but wants a faster engine as well, I'm itching to do an alloy fairing, so I'm biting. I've been told by someone that the cb550 is slow and heavy and probably won't be a good candidate, I was looking at the gs550 as a possibility. It looks to be about as heavy and slow as the cb550, but has very low compression stock and a dohc, so would it be a potential candidate for a hot cam, overbore and high compression pistons? I would probably model the body around something like the 50's augustas, so the dohc would look proper too
    Nov 2008
    Your Moms House, USA
    Handles weird. Even a stock engined gs550 with appropriate jettings (rad: fix EPA bullshit) makes them damned fast.
    How fast does he want it? I'm building some 675's right now that should be (quite a bit) more than 70hp at the crank with gs550 bottom ends.
    Sep 2008
    he's not tracking it, just wants it to be faster than stock, not one of those "race looking bikes". do you think jetting, a competent rebuild, bumped compression and a tuned exhaust would do it?
    Senior Member monkey's Avatar
    hull, mass, USA.
    leave it stock
    latered
    Nov 2008
    I'll tell you exactly what will do it:
    Remove airbox lid (leave in filter)
    Main jets to 112.5 to 120's, depending on location.
    One size up on idle circuit jet. Maybe two, but doubtful.
    That's it. That's all it takes.
    The gains for doing this on the GS550 are absurd. No other bike I've fucked with has the same kinds of returns with a simple slight derestriction and jetting change.
    (The above is for the 80 and later gs550's with CV carbs. I haven't done the earlier ones, nor ridden one, with regular slide piston carbs. The earlier ones may not respond as well. Head is a bit different, mainly on intake tract dimensions.)
    Nov 2008
    The early slide carb models needed a lot of work, but, you could get ports a really good shape and flow.
    I spent about 12~14hrs on the first intake port then the others went quite quick (about 25~30 hrs in cyl head)
    Set of cams, real race exhaust, carbs bored 1.25mm, big bore kit (forget how big, 718cc?)
    It was a LOT faster than Honda VF 750 (geared for 175mph would almost pull red-line)
    Speedo never read over 93mph
    Nov 2008
    Well there ya go.
    Nov 2008
    Or, rather, Bob's yer uncle.
    Sep 2008
    yeah, I looked for a big bore for it when I saw it on CL, couldn't find one available though. there was one in Syracuse for about $300, I shoulda just made the drive and snagged it, now I'll probably never find one again haha
    Nov 2008
    Seriously don't need to go big bore for someone who isnt going ot race it. If you just do the stuff I said, assuming it's 80 or later. And you can try with the earlier ones, too.
    I reckon mechanical slide piston carbs would take to velocity stacks a fair bit easier than the CV's.
  1. 81 gs550 sputtering
    By TheKillerSN95 in forum Project Builds
    Last Post: 08-25-2012, 02:33 PM
  2. 78 GS550 Project
    By silverc10 in forum Project Builds
    Last Post: 05-31-2012, 07:48 AM
  3. GS550/650/750 Build
    By roccitycafe in forum Project Builds
    Last Post: 02-28-2012, 05:36 PM
  4. gs550 Tuning
    By Fox in forum Technical
    Last Post: 01-11-2011, 04:12 AM
  5. GS550 parts
    By oldschoolorange in forum Parts For Sale
    Last Post: 04-17-2008, 10:38 AM
78 suzuki gs550 mods
81 suzuki gs550 performance mods
big bore kit for gs550 1980
gs550 big bore
gs550 exhaust port size
gs550 performance
gs550 performance camshaft
suzuki gs550 big bore kit
