'75 Z1b project - Page 2
'75 Z1b project
This is a discussion on '75 Z1b project within the Project Builds forums, part of the Caferacer.net Forums category; Got some work done today... Pulled off the front quarter fairing, rear fender, blinkers, and luggage rack. Then I mounted an old lucas tail light ...
Page 2 of 36 FirstFirst 123412 ... LastLast
Results 11 to 20 of 356
Like Tree28Likes
Thread: '75 Z1b project
  1. #11
    Feb 2009
    Fort Knox, Kentucky
    Then I mounted an old lucas tail light under the cowl, put on some aluminum bullet blinkers, threw on a stock seat I had, and started on installing the rearsets. One annoying problem is that I can't get the bike to shift out of neutral or first... I'll have to pull the clutch apart and see whats going on.
    Also, I'm trying to figure out how to use the stock rear brake return spring with the rearsets (is it wrong to assume that it's not meant to be re-used?) I may end up going out and trying to find a spring that will work :/
    Additionally the rearsets didn't come with any sort of threaded clevis for the brake rod, but I just grabbed one of an extra set of tommasellis I had.
    Sorry for the cell phone pics, my camera didn't make it out of Astan alive.
    Also, along the lines of Geetos suggestion on the gunfighter seat, I've fallen in love with the Z1 Giuliari seat... the quest begins.
    Tomorrow I'll work on tackling the rearset brake spring problem, wire up the tail lighs and blinkers, call the previous owner and get him to help me with the shifter, and possibly throw on the clipons, headlight ears, front blinkers, and fix the master cylinder.
  2. #12
    Senior Member JPellegrino's Avatar
    Sep 2010
    NYC, NY, USA.
    welcome back dude![8D]
    "Its amazing what can be done when you don't know you can't do it" Bill Anderson
  3. #13
    Sep 2010
    NYC, NY, USA.
    Senior Member hahnda's Avatar
    Dec 2006
    Cameron, WI, USA.
    There are three balls on the sprocket shaft of the trans that stop second gear from engaging. Once the bike is rolling the centrifugal force moves the balls into the gear and the gear can move into position. It was designed this way to make finding neutral easier.
    If you have it on the centerstand and can spin the wheel you might get it moving fast enough to work. I have spun the shaft by hand on the bench fast enough to get it to shift.
    http://www.scramblercycle.com
  6. #15
    Dec 2006
    Cameron, WI, USA.
  7. #16
    Feb 2009
    Fort Knox, Kentucky
    wow.
    much appreciated.
  8. #17
    Feb 2009
    Fort Knox, Kentucky
    wow.
    much appreciated.
  9. #18
    Feb 2009
    Fort Knox, Kentucky
    Hey guys,
    Got almost everything installed...
    Clipons, bar end mirror, rearsets (just have to find a suitable rear brake lever return spring) etc.
    I also got some longer bolts and spacers to lower the gauge cluster down about two inches, and installed some new exhaust gaskets.
    Took Geetos advice and got myself a corbin seat on ebay for a song (it's great when people don't list the model the seat is for in the title... really cuts down on the number of bidders) but I have to figure out how I'm going to lock it down seeing as the catch pin doesn't line up.
    Regardless, all I have left to do is put some fresh tires on it (and possibly a new chain and sprocket even tho the ones that are on there currently have never really been used), wire up the blinkers and taillight, and finish rebuilding the front brakes.
    once again, crappy cell phone pics.
  10. #19
    Feb 2009
    Fort Knox, Kentucky
    Hey guys,
  11. #20
    Nov 2008
    Put a fork brace on it before you get hurt
cafe racer windscreen
giuliari seat z1
https://www.caferacer.net/forum/project-builds/17366-75-z1b-project-new-post.html
rc engineering distributor drive
z1 giuliari seat
