new norton tipe frame we are building
This is a discussion on new norton tipe frame we are building within the Project Builds forums, part of the Caferacer.net Forums category; this is a new frame we have just made to take the hinkley triumph engine we are building .we made it so it will allso ...
Results 1 to 10 of 18
    Member walker brothers's Avatar
    Apr 2012
    uk, yorkshire, United Kingdom.
    this is a new frame we have just made to take the hinkley triumph engine we are building .we made it so it will allso take the oil coold gsxr 750 and 1100 engines and the harley davidson sportster engines as we are building 2 bikes .it will allso take more engines . as it is 40mm taler then the standar frame and is 10" wide at the rear .all in all it turnd out well .will post more picks as the build moves on
    thers more stuff we are building on the new blog http://walkerbrotherscaferacer.blogspot.co.uk/
    Mar 2006
    south Orange County, CA, USA.
    How does your new frame compare to the stock Hinckley frame in handling? And in weight?
    Mar 2006
    More importantly - I don't see any of the necessary bracing to make a featherbed handle. Stock the frame wasn't as good as everybody has been led to believe, I needs a few braces to make it a world beater.
    Senior Member monkey's Avatar
    hull, mass, USA.
    Agreed
    latered
    Apr 2012
    the frame as no bracing in ther yet thers still more to do to the frame ;0
    Apr 2012
    weight is far less then the Hinckley frame .as for handling we are hoping to have a track say bike up and running this year ;0
    Member 550Kafe's Avatar
    May 2012
    New Bern, North Carolina, USA.
    Any plans to make frames for the Honda CB's?
    77 CB550K
    79 GS1000
    73 CB350 Twin
    74 TX500
    Apr 2012
    i fink the cb engines will go in ther if not we can make the frame longer to take one
    Dave Deegans from Dresda makes an FB that fits a cb750 engine. what's really sad is he had an amazing frame design for the SOHC in the 70's that there just isn't call for these days:
    Other engines that usually will fit a stock norton FB without significant modification to the structure:
    - old triumph/BSA parallel twins and triples
    - Vincent Single (the twin will go in as well but it is significantly more work because of the rear cylinder)
    - Ironhead Harley sportster motor (flathead K-bike mills as well but no big twins)
    - xs650 (but it looks goofy)
    The air/oil cooled gsxr is interesting. I have seen one before but as far as modern sport bike mills, that is one that I would really be chuffed to see.
    I have seen enough new bonnie motors in FB's to be bored of them already (someone is already cranking out the frame but I forget who).
    walker bros: good work but you have a long way to go. I never understand why people post pics of stuff this early in the project. there is not enough meat there to get excited about and you'll invaribly draw "you are doing it wrong" kind of comments. Honestly even I am like "you need bracing" for it because there are so many FB knock offs out there.
    Just once I would like to see a seely cb750 (Kenny Cummings does norton seelys), or a Martin Framed something, or even some of the old rickmans done over in cromoly.
    still, keep up the good work.
  1. 1963 Norton Electra 1962 Norton Navigator $300
    By nic579 in forum Bikes For Sale
    Last Post: 10-08-2011, 10:36 AM
  2. Building bike from frame up.
    By HasteTheMoment in forum General
    Last Post: 11-07-2008, 11:26 AM
  3. wheel building
    By midge in forum Technical
    Last Post: 01-22-2008, 08:53 AM
  4. frame building ???
    By bulldog21 in forum Technical
    Last Post: 09-14-2007, 11:56 AM
  5. help building one of these
    By sule in forum General
    Last Post: 03-31-2004, 08:07 PM
featherbed frame builders
featherbed frame for hinckley triumph
featherbed frame for sale
featherbed frames for sale
norton featherbed frame
norton featherbed frame for sale
norton featherbed frames for sale
norton frame for sale
norton frames for sale
