Honda CB550 Cafe Racer Project
This is a discussion on Honda CB550 Cafe Racer Project within the Project Builds forums, part of the Caferacer.net Forums category; Hi all, I found the site whilst searching for ideas and inspiration for my 1st Cafe Racer project. Its a 1977 CB550 F2 Supersport, its ...
Results 1 to 8 of 8
    Sherlockh is offline
    Junior Member Sherlockh's Avatar
    Jul 2012
    , , United Kingdom.
    Its a 1977 CB550 F2 Supersport, its a barn find and quite frankly its a bag of shite (for now)
    I have started stripping the bike down, all thats left is the front end and motor, I wanted to try and start the bike before stripping the engine. (is it worth it??)
    I have already begun to strip the carbs completely and rebuild along with treating them to an ultrasonic bath, when it arrives.
    I will, for those interested keep you updated as much as I can, I have set up a blog for my own record and for anyone interested in following the build. www.acaferacerisborn.wordpress.com
    Any help, advice, tips and tricks would be more than welcome!
    kerosene is offline
    Jan 2008
    Southern Finland
    well you should have asked before you stripped it down because here the most common advise is not to strip the bike before you have fixed all mechanical issues one by one.
    Didn't check the link - post pics here please.
    Jul 2012
    , , United Kingdom.
    Thanks for the reply
    The bike electrics, engine etc is still on the bike, the only things stripped at present are;
    rear wheel
    swing arm
    rear shocks
    rear fender
    battery box
    air filter box
    tank
    seat
    down pipes (rotten)
    carbs are off to clean
    I intended to put the carbs back on and try and get it started although some of the wiring looks a bit dodgy
    any advice on how to get the bike started? procedure, what to look/check for baring in mind it hasn't been started for 15 years, there is good compression
    joe c is offline
    Moderator joe c's Avatar
    Mar 2002
    , , Turkey.
    thats not a 77 seat. thats not a stock pipe either for a ss. tank looks like it could be a 77. the seat sitting behind the bike indoors looks like a 77 seat. the 77 and 78 seats were different than any other year because of the shape of the tank. the 77 was flat. the 78 had a little upstep.
    the ignition switches are notorious issues with these. aftermarket are junk. and i have to go back and look, but i dont think those are 77 carbs.
    Jul 2012
    , , United Kingdom.
    The seat indoors is the same seat. I am aware the exhaust isn't stock and was replaced at some point in its life as is maybe the seat.
    Carbs are the '77 f2 S/S http://www.cmsnl.com/honda-cb550f2-s...7.html#results
    As is the bike according to the VIN
    joe c is offline
    Mar 2002
    , , Turkey.
    hmm......im too lazy to dig out my book, but it makes me wonder if the ss had a different seat than the k. i didnt think it did. and now i wonder if the carbs were different. hmmmm.......
    jaguar is offline
    Senior Member jaguar's Avatar
    Dec 2005
    Albany NY
    Im almost sure that the seats were different K vs F
    Just slightly less sure that the carbs are different too
    Check out SOHC4.net
    I am Derby\'s Bitch
    joe c is offline
    Mar 2002
    , , Turkey.
    i think youre right about that jag
  1. 1974 Honda CB360 Cafe Racer Project
    By wtfbbq in forum Project Builds
    Last Post: 02-27-2013, 05:34 PM
  2. 1972 Honda CL100 Cafe Racer Project
    By wasp in forum Project Builds
    Last Post: 08-31-2012, 02:07 AM
  3. Honda cb500 four Cafe racer Project
    By MattRogers in forum Project Builds
    Last Post: 12-14-2011, 05:30 PM
  4. 1978 Honda CB550 - first cafe project starts here
    By rguirlando in forum Project Builds
    Last Post: 10-05-2010, 10:37 AM
  5. CB550 Cafe Racer
    By Brentadour in forum Bikes For Sale
    Last Post: 05-11-2008, 07:21 PM
cb550 cafe racer
cb550 forum
honda cb 550 forum
honda cb 550 forums
honda cb550 cafe racer
honda cb550 cafe racer project
honda cb550 forum
honda cb550 forums
honda cbx 550 f2 cafe racer
