8Ball's winter project - Page 12
This is a discussion on 8Ball's winter project within the Project Builds forums, part of the Caferacer.net Forums category; So, my original speedo took a crap the last time out. The needle broke in half and the stub just started pointing at whatever the ...
Page 12 of 12 FirstFirst ... 2101112
Results 111 to 120 of 120
Like Tree17Likes
Thread: 8Ball's winter project
  1. #111
    Senior Member 8ball's Avatar
    Nov 2012
    East TN
    So, my original speedo took a crap the last time out. The needle broke in half and the stub just started pointing at whatever the heck it wanted to.
    I thought about getting a nice Kosco one or similar, but at around $300 for the ones I would want, it just didn't make sense. All I need is a somewhat accurate tach and a speed signal. I found this universal gauge on Amazon for around $30.
    It comes with the speed pickup and magnets to be mounted on the wheels. The connectors are OEM style, but only come with the male plugs. I bought connectors from Cycle Terminal and ordered a Molex style crimper from Amazon to make the correct crimps on the pins. (More on that later when I get to the wiring).
    First order is to get the brackets made. I started with a piece of cardboard and some 16 gauge steel sheet metal for the gauge mount:
    Mock it up and get my correct shape:
    Then I start cutting with tin snips, a cut off wheel and a dremmel to get it where I need it. Drilled the bolt holes, then used my bench grinder and wire wheel to buff smooth the edges:
Size:  82.4 KBName:  248.jpg
Size:  91.5 KBName:  249.jpg
    And here it is...
Size:  76.5 KBName:  251.jpg
    Painted black and on the bike:
Size:  89.0 KBName:  266.jpg
    Tanshanomi and K9Swine like this.
    My GS550 Build Thread
  2. #112
    Nov 2012
    East TN
    Next Was to mount the magnets to the wheels somewhere. I chose to use the rotor bolts, and fabricate brackets that went between two rotor bolts. I used the same method as before using a cardboard template, only I used thinner 18 gauge sheet metal for these. I had the old single rotor that was originally on this bike as a mock up.
Size:  96.4 KBName:  253.jpg
Size:  93.3 KBName:  254.jpg
Size:  110.5 KBName:  255.jpg
    Actually mounted on the wheel. (They need just a little more trimming so the lock tabs would still lock on the bolt heads)
Size:  86.4 KBName:  262.jpg
    knappyfeet and CaTacL1sm like this.
  3. #113
    Nov 2012
    East TN
    The most complicated bracket was the speed sensor bracket.
    I bent and attached the upper part of the bracket to the caliper bolt:
    Marked the shape and location for the lower part of the bracket where it will go around the axle/speedo drive spacer:
    Rough cut:
    Attachment 71761
    Located the hole for the sensor and painted it:
    Mounted up:
    I am in the process of wiring it up. It would be much faster, but I like to try to make things as OEM looking as possible..... No butt splices for me.
    Jan 2015
    San Diego, CA
    Good for you for making it work.
    Mine never worked that good.
  6. #115
    Nov 2012
    East TN
    Quote Originally Posted by knappyfeet View Post
    Yeah well....we'll see how well it works. I haven't finished the wiring, yet. From what I can tell, the most troublesome issue is the tach signal. Hooking it up to the coils seems to be too much for it, according to my research. I may try experimenting with connections at the Dyna Ignition, but more than likely, I will use an inductive loop around a spark plug wire, and heat shrink it to the plug wire. As I said, we'll see....
  7. #116
    Sep 2009
    Kansas City
    Quote Originally Posted by 8ball View Post
    Does yours actually have the CFMoto brand name on the face? All the ones I found on Ebay said "DSP SYS" in that location.
  8. #117
    Nov 2012
    East TN
    No. Mine says DSP SYS.
    Tanshanomi likes this.
  9. #118
    Nov 2012
    East TN
    Having trouble with the tach signal, at this point. It is designed to connect to a pulse generator signal to an ECU, not a points type ignition system. And to make matters worse, I have a DynaS system on mine, so I am working through that. This may take a bit.....
  10. #119
    Sep 2009
    Kansas City
    Did you ever get the tach working for this unit?
  11. #120
    jcw
    jcw is offline
    Senior Member jcw's Avatar
    Jul 2015
    chicago burbs
    There are a couple clip on inductive devices that can pick up signal on the coil wire instead of plug wire.
    Ive used it before on a canbus bmw where the tach signal is electronically buried in a single communication wire between the ecu and dash.
    Ill look for it if anyone is interested.
    Edit- https://www.msdperformance.com/produ...ers/parts/8918
    Honey, where's the Bactine?
  1. winter project gn1100g
    By gigerracer in forum Project Builds
    Last Post: 01-27-2011, 01:03 PM
  2. RD 350 Winter project
    By With in forum Project Builds
    Last Post: 10-27-2010, 08:46 PM
  3. Wanting a Winter Project
    By Brian in forum General
    Last Post: 04-04-2008, 07:18 PM
  4. winter project CB550
    Last Post: 01-08-2008, 03:27 PM
  5. my winter project
    By Bugg in forum General
    Last Post: 02-04-2006, 08:25 AM
raask rear set cb550
rear motorcycle brake pivot both ways
rebuilding rfy shocks
rfy shock rebuild
rfy shock remove lock nut
rfy shocks gs550
rfy shocks mounted upside down
rfy shocks rebuild
upside down rfy shocks
