8Ball's winter project - Page 14
This is a discussion on 8Ball's winter project within the Project Builds forums, part of the Caferacer.net Forums category; The hose isn’t being forced in any shape. There isn’t much tension on the band. Just enough pressure to prevent the hose sliding over the ...
Page 14 of 15 FirstFirst ... 412131415 LastLast
Results 131 to 140 of 142
Like Tree20Likes
Thread: 8Ball's winter project
  1. #131
    Senior Member 8ball's Avatar
    Nov 2012
    East TN
    The hose isn’t being forced in any shape. There isn’t much tension on the band. Just enough pressure to prevent the hose sliding over the barb on the fitting.
    And the devices you are referring to? I call them Satan Clamps, because that is who I am convinced was the original designer. There isn’t enough room for one of those, either. The two protrusions that face the center prevent the ability to get a pair of needle nose in there. And I am afraid the tabs would hit the protrusions, acting to relieve the clamp pressure. It is a really tight space.....specially with that thick fuel hose that’s on it.
    My GS550 Build Thread
  2. #132
    Nov 2018
    Augusta, GA
    You need band and buckle clamps, or band clamps. They are both low profile, much more reliable and they get a good tight seal. McMaster sells kits for the band and buckle clamps, or the band clamps per unit.
  3. #133
    Aug 2012
    grants pass, OREGON, USA.
    ive bin to banned camp
    Nov 2012
    East TN
    So I took the bike out with the new bars and it was comfortable....until the pace wicked up a bit. I found that if I didn’t trail brake all the way past the apex of every curve, the front end would start skipping and try to fold up on me. It felt good under braking, but mid corner it was scary. Symptoms that point to either too much spring rate, or lack of rebound damping.
    With the new bars, my new body position took weight off the front end. So the first step was to remove it 12mm preload spacers I had on top of the springs. I took the bike out again and it was better, but the front still seemed a little bit unsettled. The next step was to increase the fork oil wt. So I went from 15wt to 20wt. Hopefully that will cure the front end blues.
    jcw likes this.
  6. #135
    jcw
    jcw is offline
    Senior Member jcw's Avatar
    Jul 2015
    chicago burbs
    I like people that aren't afraid to experiment with and dial in the forks...
    So what you are saying is by trailing the brakes, you are forcing the front end to stay down. Once you let off the brakes, the front springs up too fast and feels vague.
    Makes sense. increasing rebound dampening and a thicker oil will slow the rebound but ultimately you might need a lighter front spring.
    Dropping the front end will help with weight transfer onto the front and help keep the front loaded.
    keep it up and post your results...
    Oh yeah, loose head bearing preload and wheel bearings can cause a similar situation as well as tire condition and way off tire pressures.
  7. #136
    Nov 2012
    East TN
    With the 20wt oil, and the preload spacers removed, the bike felt much better entering corners and through the middle of the turn. The absolute need to trail brake hard into a turn to avoid chatter, and the tendency of the front wheel to fold mid-corner were gone. The only issue was that the front felt a bit sloppy at the top of the stroke. I could feel the lack of any spring tension at full extension.
    One of the guys I regularly hang out with at the Deals Gap restaurant had a small air pump in his bag, so I put 5 psi in each leg and made a few more passes. It was like a switch got turned on! I was literally giggling in my helmet because it was handling so well.
    That feeling of euphoria that happens when a bike is railing through turns better than it was ever designed to do is something the angle grinder wielding “art-bike” crowd will never experience..... And that is a shame!
    TrialsRider and woodsman like this.
  8. #137
    Holy I wish I had an autobahn like that near where I live :|
    you should invest in a low pressure air gauge and a mini air pump like the one I carry for the trials bikes.
  9. #138
    jcw
    jcw is offline
    Jul 2015
    chicago burbs
    Quote Originally Posted by 8ball View Post
    This is the same feeling I'm having with my trackbike at the moment.
    I'm riding yesterday and thinking, damn, this thing is doing everything I'm asking it to do. And with minimal effort, too. The only limit is how hard to I want to push it on the street.
    It's a great feeling...
    And most of it has to do with setting up the bike rather than expensive new parts. Granted an older bike (30-40yo) is gonna benefit more from newer technology...
    Of course that means actually riding the bike to know where it needs attention. Another thing that the artsy-fartsy crowd doesn't understand either...
  10. #139
    Nov 2012
    East TN
    I’ve only had my R6 out once, this season. I’ve been out on the GS about a half dozen times, so far. The R6 is so much easier to get through the road, at a much faster pace, but the old bike is much more visceral and is becoming just as much fun.....even at a 10-15 mph slower pace.
  11. #140
    Junior Member Mackey's Avatar
    Dec 2019
    Hi,
    this is Lukas from Germany. I also wrote you an private message, but I Think you did not see it yet.
    I fortuitously found your thread in Google about the pod filters on Mikuni VM22 carbs on a 1979 Suzuki GS 550.
    I am also building up a GS550 and it was very interesting for me to see your pictures that with normal low cost pod filters the air passages are blocked / could be blocked. So I decided to buy the K&N pod filters shown in your thread.
    And now my question:
    Could you please tell me your carb settings with the K&N installed? Main jet size, pilot jet, Needle,..?
    That would be very great and a big support for me and my project
    Thank you.
    Best regards
    Lukas
  1. winter project gn1100g
    By gigerracer in forum Project Builds
    Last Post: 01-27-2011, 02:03 PM
  2. RD 350 Winter project
    By With in forum Project Builds
    Last Post: 10-27-2010, 09:46 PM
  3. Wanting a Winter Project
    By Brian in forum General
    Last Post: 04-04-2008, 08:18 PM
  4. winter project CB550
    Last Post: 01-08-2008, 04:27 PM
  5. my winter project
    By Bugg in forum General
    Last Post: 02-04-2006, 09:25 AM
raask rear set cb550
rear motorcycle brake pivot both ways
rebuilding rfy shocks
rfy shock rebuild
rfy shock remove lock nut
rfy shocks gs550
rfy shocks mounted upside down
rfy shocks rebuild
upside down rfy shocks
