1978 Honda CB750 SOHC F2 SS- Monoshock Conversion
This is a discussion on 1978 Honda CB750 SOHC F2 SS- Monoshock Conversion within the Project Builds forums, part of the Caferacer.net Forums category; ??????????...
Results 1 to 10 of 18
    Junior Member Tayflyer's Avatar
    Feb 2014
    Senior Member Teazer's Avatar
    Mar 2010
    , IL, .
    Hornet (?) tank looks good but ideally the bottom surface needs to be flat or the back end could be dropped and side panels integrated somehow.
    Of the dozens of times I have been through/to Fife it always seemed to rain. Must just have been my bad timing I guess.
    Jan 2008
    Southern Finland
    The problem with mono swaps is that the wheelbase tends to stretch in the swap. This looks ugly and makes the bike less nimble. How much longer is the new swing arm?
    What he said^^^
    You'll get another 2 inches in wheelbase at least. Might be a good thing, might be a bad thing depending on what you want the bike to do.
    Another option is to use the FZR swingarm as a twin shock. Just weld some shock mounts onto the top of the arm near the rear axle. Then (if you're keen / can weld alloy) you could cut out the monoshock section and shorten it to the same length as the CB arm. All depends on how far you want to go.....
    The good news is that the FZR600 swingarm is not alloy, it is steel, so it is possible to just shorten it from the axle end to get the same wheelbase as original.
    WERA 119
    CCS 119
    CRA 119
    AHRMA not anymore
    Evan Esar
    Junior Member CafeGav's Avatar
    Nov 2013
    Klerksdorp South Africa
    What he said^^^
    As Hillsy said this can be done, I done it on my alloy swinger and scored 2 inches, i did not go the twin shock route but rather horizontal shock mount, here is the link
    https://www.caferacer.net/forum/proje...s-retro-2.html
    Gavin
    Current Ride
    Yz250 LINK
    Project Bikes
    1981 RD350 LC Hybrid
    1983 RD350 YPVS LINK
    1975 KH400 Triple Cafe Racer LINK
    just from what I know about cb750 frames and not much else, You would want the upper shock mount to be right where the frame junctions under the fuel tank. Why? it's really strong there.
    Junior Member Scotlandcaferacer's Avatar
    Jul 2014
    CB project
    Found your project Tay, looks great.
    I'm from Falkirk area and run a Facebook page/group called Scotland Cafe Racer.
    Have a look and give the page a like, you can then post some photos of your project, the guys would like to see what your doing.
    Might even see you out on the road when it's finished. Got a good few guys from up your area on the page.
    Cheers
    Banned Witworth's Avatar
    May 2014
    West
    Like GT said. Also, the stresses at monoshock upper mounting points could be ten times the shock and force loads of a twin shock upper mounts. Leverage and multiplication factors with shock linkages, etc.
    In short you need strong tubes and brackets that feed the stresses directly to where GT said.
    Danger, is my business.
    "Also, the stresses at monoshock upper mounting points could be ten times the shock and force loads of a twin shock upper mounts."
    :/ what did you do, park a car on it.
  1. 1978 Honda CB750 Cafe Project
    By lucky13cycle in forum Project Builds
    Last Post: 02-16-2014, 05:43 PM
  2. Honda CB750 F2 1978 thats what I want
    By schavuyth in forum Project Builds
    Last Post: 09-28-2011, 08:59 AM
  3. NOS CB750 SOHC pistons
    By crazypj in forum Parts For Sale
    Last Post: 03-16-2009, 11:37 AM
  4. CB750 SOHC 4 into 1
    By Wanker in forum Wanted
    Last Post: 01-27-2009, 04:12 AM
  5. 1978 Honda CB750 K parts
    By Johnmw in forum Parts For Sale
    Last Post: 11-09-2007, 03:23 AM
alloy wheels for honda sohc 750
cb 500 monoshock conversion
cb750 monoshock
cb750 monoshock conversion
cb750 monoshock conversion kit
cb750 rear swingarm conversion
honda cb 750 mono shock
monoshock conversion cb750k
