Need to make this seat fit!!! Need some ideas...
This is a discussion on Need to make this seat fit!!! Need some ideas... within the Project Builds forums, part of the Caferacer.net Forums category; Ok so I have my Gs750 running-ish now. I think I just need to do some carb adjustments. Anyway, I have this Ducati seat I ...
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 32
    Senior Member The Chief's Avatar
    Feb 2014
    Watertown, NY
    Ok so I have my Gs750 running-ish now. I think I just need to do some carb adjustments. Anyway, I have this Ducati seat I really want to make fit on the bike one way or another. I have never "fabricated" a seat to fit so im not sure of the methods or tricks of the trade to make it happen. The front of the seat is a little too narrow for the tank, so my thought process was to hit the bottom of the seat with a heat gun and soften it up a little so its pliable and make it fit. But when it comes to figuring out how to SAFELY secure this seat to the frame, Im at a loss....
    I didnt chop the frame, was like that when i bought it....so I got to work with what I have. Here are the pics of what im working with.Name:  asd.JPG
Size:  711.8 KBName:  dsad.JPG
Size:  532.8 KBName:  erw.JPG
Size:  743.9 KBName:  photo 1.JPG
Size:  615.4 KBName:  photo 2.JPG
Size:  449.4 KBName:  photo 3.JPG
Size:  480.9 KBName:  photo 4.JPG
Size:  473.2 KBName:  photo 5.JPG
Size:  381.5 KBName:  photo.JPG
Size:  357.7 KBName:  sdsa.JPG
    He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors.-Thomas Jefferson
    That Monster seat was designed to sit angled up. Your frame rails are flat. It's gonna look strange if it's flat....as well as probably not be very comfortable. And it's gonna look stupid if you angle it (unless you weld on a new rear end to the bike).
    You might want to go for a more traditional bum-stop seat. Hipsters everywhere with CX500 swoopy rear triangles are insanely jealous of your frame.
    Senior Member dirkchecken's Avatar
    Jan 2012
    I like my shocks like I like my women. Cheap and Chinese.
    Feb 2014
    Watertown, NY
    I wish I knew what this meant!! lol
    You ain't going to make that fit. However you can make a pan and then shape foam to look like that seat and then take it to an upholsterer to get it covered.
    Quote Originally Posted by The Chief View Post
    Look at the rear triangle......
    Kinda hard to hide that swooping steelwork.....
    Almost forgot - here's a pensive hipster wishing his CX subframe was like your GS one:
    Jun 2008
    SE MI, USA.
    Do it the same way Ducati did. The two front tabs go under, um, things that hold the tabs down. And the back post goes into a thing that holds the back post. So buy the thing that holds the post off of ebay and make the things that the tabs go under. It's been too long since I've seen a Monster to remember what the rear mechanism is but I'm guessing it's a lot like a 907 or 900ss or 996 seat of the same era in that it's a spring loaded deal that would be pretty easy to retrofit to a different frame.
    It will still look like someone found a Monster seat and cludged it onto a different bike but it will be secured anyway.
    IMHO you should sell the seat to someone with a Monster and put the money towards something with a more universal fit. Or buy a stock pan for that bike and modify the seat on that. If I'm modifying things I'd much rather start with something that fits... And yeah, that seat is designed to be fit so the rear surface is more or less level when installed.
    BTW I've modified Ducati seat pans with heat, it works to a point but you'll never get the front contour to match that tank.
    -Craig
    Feb 2014
    Watertown, NY
    Quote Originally Posted by DesmoDog View Post
    Ok, well I suppose I will have to find another seat. The problem still exists though with not bein able to secure it to the frame. There are not brackets or anything.
    ok, you need the seat first to then figure out how it is going to mount. However, there is a guy who sells "mounting blocks" for cb750s on SOHC4.net that might be modified to fit your gs750. He makes them in 3/8" and 3/4" inch sizes so measure your frame tubes. here is the link the blocks are towards the bottom.
    FB-stuff STORE - aftermarket SOHC plastic covers, clear points covers, DIY cafe seat kits
  1. cafe seat ideas?
    By jason41987 in forum General
    Last Post: 09-24-2012, 10:58 PM
  2. Replies: 9
    Last Post: 02-04-2011, 11:25 PM
  3. Some cafe racer seat ideas I had
    By Kevvo16 in forum Project Builds
    Last Post: 11-28-2010, 12:25 AM
  4. Cafe seat for the Cb360. Ideas?
    By Matt N in forum General
    Last Post: 01-25-2008, 07:20 AM
  5. make you own damn seat..its your arse!!!
    By LiLBull in forum General
    Last Post: 12-20-2005, 06:36 PM
cafe racer hispeter style
cx 500 rearsets
cx500 honda cafe racer
gl500 cafe racer
gl500 cafe seat
honda cx500 rearsets
honda gl 500 caf? racer
ideas for making a gs750 cafe bike
is a cafe racer seat hollow on the bottom?
