1978 Suzuki GS750E
1978 Suzuki GS750E
This is a discussion on 1978 Suzuki GS750E within the Project Builds forums, part of the Caferacer.net Forums category; Oh, boy!...
Results 1 to 10 of 15
    Junior Member Raw_Potato's Avatar
    Sep 2014
    *no thread*
    Oh, boy!
    Probably handled a bit weird, eh?
    Senior Member TCed's Avatar
    Dec 2011
    traverse city, mi, USA.
    did you ride it prior to disassembly ?
    Sep 2014
    I did not. The fellow that DID ride it, did so for a LOOOONNNGGG time. The front tire is quite warn off center. I got the bike assembled minus a few lights and nuts/bolts. It came with an extra engine and carb cluster. It wasn't running when I brought it home but I was able to get it running in about two hours. I didn't notice the wear on the tires until I started cleaning the bike and breaking everything down. The forks are slightly bent.
    Senior Member o1marc's Avatar
    Sep 2012
    Dawsonville, Georgia, USA.
    Is that front frame tube bent as bad as it looks in the pic? How could you not possibly see that when looking at the bike. I would have run from that deal unless they were paying me to take it away for salvage. I bought a 78 GS750E new.
    www.CreativeCandy.org
    so...now that you have a pile of GS750 parts... what are you going to do?
    that frame is borked - it will never be a motorcycle again.
    a) GS750 frames are cheap so it isn't worth it to straighten financially.
    b) the frame construction is as such once bent it really will never be straight again. If you notice it is a lot of pressed metal and tubes spot welded together badly. You'll always be chasing cracks.
    c) if you have the skills to make a frame jig, then presumably you have the skills to make a new frame. If that is the case then why not do a little research and then use the neck (and your existing title) to make something like a Bimota SB2 replica frame (the bimota SB2 used the GS 2 valve engine in a really good chassis:
    Sep 2014
    like that idea Geeto and do have a second 2 valve gs750 lying around lol
    Senior Member Emit R Detsaw's Avatar
    Oct 2009
    Phoenix, AZ, USA.
    Tell Dave Steele that Don the Air Force Guy said Hi. I used to work for him part-time back in the late eighties. Like he'd remember me. Is he still located off Santa Fe Blvd? I buried an AR80 in the very back northwest corner of his lot back then and forgot about it. It was a Canadian model with green bodywork and a km/h speedometer. Could you see if it is still there? Not really. Have a good time.
    I believe we have run out of trolls.
    Sep 2014
    Looks like they are located on West Union which is off of Santa Fe. Ill tell him you said hi and see if that bike is still there for ya(needle in haystack?haha) Its a pretty dreary day in Colorado today. Hopefully the rain holds off for the rest of the afternoon.
  1. 1978 Suzuki GS750
    By The Chief in forum Technical
    Last Post: 03-02-2014, 03:50 AM
  2. 1979 Suzuki GS750E, lightly modified (Indiana)
    By gearheadE30 in forum Bikes For Sale
    Last Post: 12-29-2013, 07:50 PM
  3. 1978 Suzuki GS400
    By motosapo in forum Project Builds
    Last Post: 11-16-2011, 06:13 PM
  4. 1979 Suzuki GS750E
    Last Post: 09-19-2011, 03:30 PM
  5. 1978 Suzuki GS400, help please.
    By energie in forum Technical
    Last Post: 06-06-2010, 02:53 AM
1978 suzuki gs750 cafe racer
78 gs750 motor disassembly
bimota frame for gs750
bimota frame gs750
bimota sb2
