cb750 racing frame - Page 11
cb750 racing frame
This is a discussion on cb750 racing frame within the Project Builds forums, part of the Caferacer.net Forums category; Originally Posted by woodsman DDU- It's a British frame from the '60's. https://cybermotorcycle.com/euro/wikig/Scorpion.html Start a thread on the frame, there are some older British racers ...
Page 11 of 11 FirstFirst ... 91011
Results 101 to 107 of 107
Like Tree12Likes
Thread: cb750 racing frame
  1. #101
    Junior Member dummydownunder's Avatar
    Dec 2019
    Start a thread on the frame, there are some older British racers that are members here and are extremely knowledgeable. They may be able to give you background.
    im pretty sure that they did not make the frame in 1964 for a motorcycle that's production run started in 1969 ? or could i be incorrect ?
    its painted now !
  2. #102
    Mar 2016
    I guess I should have written "it may be".
    How do you know it was built in '64?
  3. #103
    Dec 2019
    according too the link you left thats when they made a Scorpion frame that style and closed up 1965 so if the made frames after they closed up shop i would be impressed !
    from link ......
    Scorpion
    Scorpion were motorcycles produced fron 1963 to 1965.
    In December 1963 the address is
    Scorpion Motorcycles,
    Silverstone Works,
    Whitfield,
    Brackley,
    Northamptonshire.
    Later, the address is believed to have been Bishops Stortford, Hertfordshire.
    1963 Trials and scrambles models were introduced with T-frame chassis constructed from sheet-steel box sections welded together. The frame loop had square-section tube bolted in place, so alternative engines were easy to fit although these were usually the Villiers 197cc 9E or 246cc 32A for trials and the 36A or Starmaker for scrambles.
    1964 Late in the year a road-racing model was added, this with its own Scorpion designed and made engine hung from a tubular spine frame.They were available in kit form.
    1965 Only the show prototype was seen and the make soon disappeared.
    Seems that frame of yours is an extreme departure from everything they were making back pre-65.
  6. #105
    Dec 2019
    honest;y i got so excited that you helped me i was upsent when it did not pan out mate sorry if i was abrupt
  7. #106
    Mar 2016
    Quote Originally Posted by dummydownunder View Post
    I don't know what I read but it didn't sound the same the second time.
    If you make a thread about the frame, with pictures, the odds are pretty good someone will be able to head you in the right direction.
  8. #107
    Dec 2019
    done here is a link to thread thanks
    https://www.caferacer.net/forum/proj...downunder.html
  1. who had the best cb750 frame
    Last Post: 06-15-2014, 06:39 PM
  2. CB750 Frame Mods
    By gray in forum Technical
    Last Post: 09-09-2011, 03:31 PM
  3. CB750 Frame Bracing
    By jaguar in forum Technical
    Last Post: 02-26-2011, 10:19 AM
  4. CB750 Titled Frame
    By Pietro in forum Wanted
    Last Post: 09-02-2008, 10:23 AM
  5. WTB: CB750 sohc frame with title
    By cbr900turbo in forum Wanted
    Last Post: 03-22-2008, 01:20 PM
cb 750 racing frame
cb racing
cb750 frame gusseting
cb750 frame gussets
cb750 frame modifications
head steady cb750
software caferacer.net
software design caferacer.net
weldng cb750 frame down tubes
