CB900 Cafe Racer project - Page 49
This is a discussion on CB900 Cafe Racer project within the Project Builds forums, part of the Caferacer.net Forums category; Why is your tail light mounted so high?...
Page 49 of 50 FirstFirst ... 3947484950 LastLast
Results 481 to 490 of 494
Like Tree103Likes
Thread: CB900 Cafe Racer project
  1. #481
  2. #482
    Senior Member tjurek51's Avatar
    Sep 2015
    still working on some detail items. I suspect i'll never really be done tinkering with this one.
  3. #483
    Mar 2016
    It looks like you've built a functional bike. That's unusual for the cafe crowd. You want to keep an eye on everything for a while to make sure it's sound and safe to see "how it goes".
    You really should get a decent pair of boots to ride. If that pig lands on your leg and drags you across the pavement your ankle will be fucked.
    Ya we all noticed the runners, great for running, useless for riding motorcycles, only flip-flops are worse.
  6. #485
    Nov 2014
    Melbourne, Australia
    hit 160 yet?
  7. #486
    Sep 2015
    110 mph is all I have done so far. Put about 400 miles on it this summer and so far nothing seems unsafe and the ride is stable. Did notice the front end was very stiff. Took the springs out and noticed on one of them the bottom washer was tipped up. Not sure how that happened but sure it's mechanic error. Fixed it and it rides much better.
  8. #487
    lol naturally you were on a closed course and not riding on public roads at the time.
  9. #488
    Sep 2015
    Northern MN road. well maintained, no curves, no driveways. just got it there and backed it down. got there pretty quickly too. one thing that happened tho is i started having problems shifting and keeping it in mid-range gears. turns out the Gear Stop mechanism and spring had come loose (or, the bolt that hold them in did). i put some blue thread lock on there, for whatever good that may do. any advice on how to prevent that from happening again?
  10. #489
    Senior Member Cyorg's Avatar
    May 2014
    Quote Originally Posted by tjurek51 View Post
    The blue loctite will do the job, but the bolt and whatever threads it screws into need to be squeaky clean for it to work really well. (Assuming the threads are still ok) It works best if use sometime like acetone... clean it until you can wipe the threads with a white cloth or paper towel until there is no oil residue left which usually takes more than one application of acetone. You could use brake cleaner, but I hate that stuff.... plus if I weld something that has been exposed to brake cleaner,.... the results are not good.. life expectancy wise.
    "Non urinat in ventum"
  11. #490
    This was a shaft drive conversion bike yes?
    Does your rear sprocket have a rubber cushion drive?
  1. CB900 Cafe Racer project
    By tjurek51 in forum Project Builds
    Last Post: 09-19-2015, 12:09 PM
  2. My first cafe racer project! Help me
    By Riggs119 in forum Project Builds
    Last Post: 03-06-2013, 05:13 AM
  3. first cafe racer project
    By German.poopie in forum Project Builds
    Last Post: 02-23-2013, 04:43 PM
  4. cafe racer project
    By mirancorrecaminos in forum Technical
    Last Post: 10-20-2009, 09:18 AM
  5. This is my first Cafe Racer project!!
    By Capitol A in forum Technical
    Last Post: 05-18-2007, 07:52 AM
cb900c specs
google images of honda cb750 k7 engine mounts
honda cb900c build
