tt500 into a road bike - Page 5
This is a discussion on tt500 into a road bike within the Project Builds forums, part of the Caferacer.net Forums category; You would be correct. I did learn something new though, offset woodruff keys are a thing....
Page 5 of 5 FirstFirst ... 345
Results 41 to 47 of 47
Like Tree20Likes
Thread: tt500 into a road bike
  1. #41
    Senior Member CAPTAIN AWESOME's Avatar
    Aug 2008
    Bentonville, AR, USA.
    drgonzo likes this.
  2. #42
    Aug 2008
    I bet the replacement key you have on order is not offset.
    & It definitely spun and flopped around on the tapered shaft at some point in its life.
    btw: was the key inserted in the direction of advancing the timing? or retarding the ignition as it would more likely be after being sheared?
    I believe it went full retard? Advancing timing would be counterclockwise and retarded would be clockwise if I'm understanding correctly. Hash marks on flywheel start with advanced to the left, then F for fire in betwix, and T for TDC on the right.
  3. #43
    Member expat2000's Avatar
    Jun 2014
    Just north of Oslo, Norway
    Quote Originally Posted by CAPTAIN AWESOME View Post
    Sorry couldn't resist:
    Senior Member o1marc's Avatar
    Sep 2012
    Dawsonville, Georgia, USA.
    When I was racing cars we were not allowed adjustable cam gears, so what we did was test with adjustable cam gears to get the timing spot on and then use offset keys to get the specified advance. That or once we knew what we wanted you spin the cam gear to where you want without the key and then tack weld it on.
    drgonzo likes this.
    www.CreativeCandy.org
  6. #45
    Aug 2008
    Parts came in today. Won't be able to install until Sunday, but hoping this is the last big fix for a while.
  7. #46
    Aug 2008
    And the problem is solved. For the most part at least. With the new(er) flywheel and source/lighting coils sputtering went away for the most part. It was still running rich, so I popped the needle clip from the 3rd position to the top and it cleared right up. I was able to rev throughout the range without any breaking up. It's still popping on decel but I'm going to keep tweaking carb settings and check for more exhaust leaks. Main jet is back to the 230 I started with, so I'm going to probably order a 220 and a 210 to see what happens.
    I also started wiring up the lighting. Unfortunately both voltage regulators I have won't work, so I'm waiting on the proper one to get in.
  8. #47
    Aug 2008
    Never got around to ordering main jets, but I did manage to wire up the voltage regulator and a Sigma bicycle speedometer. After verifying calibration with GPS I am road ready.
    Yesterday I wanted to see if I could click off some test miles on various terrain and see how it would act. Temps have been warmer, and it was immediately obvious I'm still too rich. Top speed indicated was 72 and it ran out of steam sputtering. Back road gravel and some rough terrain were of no concern though. Lobbing along with the 15/42 gearing was perfect keeping torque where I need it. Once jetting gets tuned in better I may consider getting an "on road" sprocket and chain set.
    Another thing I will need to address is my tank bag covers the vent on the gas cap. Standard tubing will just kink and collapse with the bag on top, so I may get another cap to experiment with. I'm thinking I can cut the straight nub off and epoxy a 90* plastic or brass elbow on.
  1. Road Trip on a Naked Bike
    By thechief86 in forum General
    Last Post: 04-22-2015, 09:19 AM
  2. new bike road trip
    By coreyjdl in forum General
    Last Post: 08-30-2011, 09:25 AM
  3. what was your first road bike
    By Dunstall in forum General
    Last Post: 10-28-2008, 04:59 PM
  4. TT500 For a paint job
    By 68grandprix in forum General
    Last Post: 05-01-2007, 11:50 PM
  5. 1 more week and my bike is ready for the road
    By Psyco Diver 69 in forum General
    Last Post: 04-15-2007, 10:13 AM
