Suzuki Intruder VS 1400 - Page 5
This is a discussion on Suzuki Intruder VS 1400 within the Project Builds forums, part of the Caferacer.net Forums category; I think your should read this through twice: TIG Process (GTAW): Tips and Techniques then smoke a joint and give it another try....
Page 5 of 9 FirstFirst ... 34567 ... LastLast
Results 41 to 50 of 86
Like Tree16Likes
Thread: Suzuki Intruder VS 1400
  1. #41
    MarkHarold likes this.
  2. #42
    Senior Member MarkHarold's Avatar
    Jul 2016
    Sassafras, Victoria, Australia.
    Thanks for advice, all good. It has pointed out several areas where I was getting it wrong. I've bookmarked it, I'll read it everytime before starting.
    TrialsRider likes this.
    Cheers, Mark
    Struth! Stone the crows and starve the lizards.
  3. #43
    Jul 2016
    Me and the dog been jiving with Bowie...'I can't explain..I'm going outa my mind...dizzy in the head... I can't explain.. I'm a worried guy..'. This is what the exhaust will look like. I just get it adjusted so, then Biscuit rocks through and smashes everything with his tail, you gotta love him.
    I'm trying to keep large radius bends, 145mm on the rear, I have to go down to 125mm on the front, and both headers are 90cm, amazing, pure luck.
    Next step is to go from cardboard to ply.
    Cheers, Mark
    Jul 2016
    A man has got to know his limitations, well that's if he wants to do himself a favour. There is no way I could have welded this tank, the metal is just too thin for me. My son's mate is doing the welding, I'm just happy to fit and tack it together, and my tacking is improving. As mentioned earlier, I messed up the slicing and dicing a bit, but it's coming together OK. I think the secret is to keep the original cuts to horizontal, vertical and perpendicular. Having said that, I will most probably make a right balls up of the 2nd tank.
    Farmer_John likes this.
    Cheers, Mark
  6. #45
    Jul 2016
    I've bought the brake calipers, 1 off a GSX-R 600 and the other off a GSX-R 750, different makes but otherwise identical. This is roughly the mounting position.
    Due to the 5mm dish in the disc, there is a corresponding offset in the caliper mounting, a pain in the butt, but because the disc modifications were pretty simple, I think this disc was the right choice. I'm not sure that this caliper is the best choice though. Another caliper with closer mounting points would allow moving the caliper closer to the forks. I think I will re-visit the re-cycle man tomorrow.
    I'm thinking of making the adaptor plate out of 10mm and 5mm stainless plate. I suppose it could be made out of aluminium, but I prefer stainless.
    Cheers, Mark
  7. #46
    Those zip ties are never going to hold
    You're attaching a cast aluminum part to a cast aluminum part and aluminum is a lot easier to shape and work with, none of it has to move around once you bolt it all up because your disc is designed to float and I'm pretty sure that calliper has pistons that push against each other, yes? ... I'd go with aluminum. Stainless looks nice in raw form but unless you have to make the parts super thin I'm not sure what the motivation would be.
  8. #47
    Sep 2009
    Kansas City
    Just be aware of where your stresses are.
  9. #48
    Senior Member o1marc's Avatar
    Sep 2012
    Dawsonville, Georgia, USA.
    The zip ties are in compression so they should be okay. You should swap them for the stronger Green zip ties though.
    www.CreativeCandy.org
  10. #49
    Sep 2012
    Quote Originally Posted by Tanshanomi View Post
    I wish there were some numbers to work with here. We know moving it makes the forces change by 2.67 times, but is that enough to make it unsafe , or just one better than the other?
  11. #50
    Feb 2009
    Fort Knox, Kentucky
    I guess the question should be: what are the max forces (to the point of failure) that the mounting points are able to withstand under the new force vectors? After that you'd need to figure out the max forces exerted by the new setup, and determine if you are under an acceptable safety margin.
    that's not even factoring in the effects of those forces over time though.
  1. Suzuki Intruder
    By steveo in forum General
    Last Post: 11-14-2018, 04:41 PM
  2. Suzuki T500 fenders, or any older suzuki tach
    By mitchberry in forum Wanted
    Last Post: 01-27-2010, 05:19 PM
  3. Suzuki TC 90, possible?
    By Tigertree in forum Project Builds
    Last Post: 09-19-2009, 02:22 AM
  4. 1969 Bultaco Matador - $1400 - san fran
    By Eurago in forum Bikes For Sale
    Last Post: 02-10-2009, 07:04 PM
  5. Yamaha Turbo 600 dragbike/Bonneville bike - $1400
    Last Post: 01-09-2009, 11:04 AM
custom suzuki intruder cafe
suzuki intruder 1400
suzuki intruder 1400 cafe racer
suzuki intruder 1400 forum
suzuki intruder 1400 tank
suzuki intruder 1500 cafe racer
suzuki intruder mask
vs1400 pant with
vs1400 tank
