1982 GN400 Horn - Page 2
1982 GN400 Horn
This is a discussion on 1982 GN400 Horn within the Project Builds forums, part of the Caferacer.net Forums category; I still think it needs whacking with a #3 phillips handle. Practically everything can benefit from that. I know it works on sticking floats and ...
Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Like Tree2Likes
Thread: 1982 GN400 Horn
  1. #11
    I still think it needs whacking with a #3 phillips handle. Practically everything can benefit from that. I know it works on sticking floats and starter solenoids.
    WERA 119
    CCS 119
    CRA 119
    AHRMA not anymore
    Evan Esar
  2. #12
    Junior Member 82SU's Avatar
    Aug 2016
    Utah, USA
    Sorry for the slow response guys, I've been elk hunting. I think that I have got it fixed. I tore of all the tape in the headlight cowl and all the way back to the battery to make sure there weren't any bad covered up connections. There was a questionable one in the headlight that I fixed but I dont think it was giving me any issues. I ended up banging the horn with a wrench because I didnt have that driver handy. After it still would just buzz I started messing with the screw on the back of the horn and ended up finding a spot where it would work when the button was hit (I had also taken off the blinker/horn/light switch to check connections) So i got it fixed to where I wanted it when I tested it and put it back together. When I got all the wires taped up and the switched mounted back together now instead of a constant buzzing when I turned the key on it was the actual horn. I got it to stop and then when I would hit the blinkers or lights it would start again. After this hint, I started looking and could actually see it arcing from the control switch to the handle bars. After I electrical taped the handle bars underneath the switch and remounted it, the short had stopped! Everything seems to work fine now, thanks guys! Im not sure if this was how I was supposed to fix it or not but it works.
  1. 1982 GN400 Service Manual
    By 82SU in forum Wanted
    Last Post: 02-22-2017, 05:29 AM
  2. 1982 Suzuki GN400 Fork Seals
    By 82SU in forum Technical
    Last Post: 08-21-2016, 09:25 PM
  3. 1971 Kawasaki Big Horn fair price?
    By Lexzar in forum General
    Last Post: 12-05-2013, 06:24 AM
  4. NAPA 125db horn?
    By o1marc in forum General
    Last Post: 01-22-2013, 07:55 AM
  5. Ideal Motorcycle Horn?
    By r.bot in forum Technical
    Last Post: 08-07-2009, 06:27 AM
Tags for this Thread
