White Trash Fabrication's Post Apocalypic 250 Ninja Street Fighter
This is a discussion on White Trash Fabrication's Post Apocalypic 250 Ninja Street Fighter within the Project Builds forums, part of the Caferacer.net Forums category; Hi I'm Julian from White Trash Fabrication (WTF for short) and this a is 250 Ninja I'm building into a custom Mad Max Street fighter. ...
Page 1 of 7 123 ... LastLast
Results 1 to 10 of 61
Like Tree37Likes
Thread: White Trash Fabrication's Post Apocalypic 250 Ninja Street Fighter
    Junior Member WhiteTrashFabrication's Avatar
    Nov 2016
    White Trash Fabrication's Post Apocalypic 250 Ninja Street Fighter $3000 Budget Build
    Hi I'm Julian from White Trash Fabrication (WTF for short) and this a is 250 Ninja I'm building into a custom Mad Max Street fighter. This is what I started with. I had to cut most of the back of the bike off. Also this build has a budget of $3000. My shop builds budget bikes. We specialize in choppers, Bobbers, Café racers/Street Fighters all built with that old school vibe, with a little bit of Mad Max, Rockabilly Rat Bike and a touch of Steampunk for good measure. So hope this build shows you that you don't need a lot of money to build something trick.
    Banned DohcBikes's Avatar
    Jan 2016
    You "Had to" cut the subframe huh.
    Had a good bike there.
    Senior Member Ichiban Moto's Avatar
    Nov 2014
    Chicagoland
    if we had better deserts in chicagoland, I would build one
    Mad Max Fury Road Motorcycles ~ Return of the Cafe Racers
    Nov 2016
    I then welded in a piece of heavy gauge pipe to build the new rear section of the bike and also well be used as the seat mount. I found this cool fender blank and proceeded to cut it up into strips so I could overlap them and make a scale look to the fender. This was as fun as it sounds lol. I extended the swingarm 5" by welding two swingarms together with sleeves inserts and then I boxed it. Then mounted the fender right to the swingarm to get the tire hugger look.
    Nov 2016
    Here a look at the Scale Fender.
    Nov 2016
    Here are some mock up pictures of what I was thinking of doing. I was playing around with stretching the red tank. Then I got a killer deal on the tank in the bottom pictures. I still had to modify it to make it work.
    Hi Julian,
    Welcome to Caferacer.net. You have pretty nice bike to start from, in fact, I believe it could be the next CB350 as far as making modifications and performance improvements. My only question is in what way have you done anything which has improved the performance or function of the Ninja 250?
    Have a great day and good luck on your project.
    WERA 119
    CCS 119
    CRA 119
    AHRMA not anymore
    Evan Esar
    Senior Member Luckypabst's Avatar
    Oct 2011
    Costa Mesa, CA, USA.
    What's the sidevalve v-twin in the Matchless frame, in the background of the first few photos?
    chris
    Assuming the "this is what I started with" photo is actually all you started with (ie: no bodywork / seat) then you wouldn't even consider trying to bring that back to life as a stock bike. And they weren't that great a bike when new anyway - fairly low spec / budget commuter bike.Interesting things you are doing. Carry on and have fun.
    Jan 2016
    holy shit dude you gotta stop. your welds are trash on the swingarm, there's no sleeve or plug welds or gusset plates plus you grinded the welds flat, it's gonna snap like a dry twig. i don't see a jig anywhere, judging by your welds and your thought process I'm banking its as straight as can be
    i wanna be nice but this is gonna break
  1. Replies: 8
    Last Post: 05-18-2016, 09:59 PM
  2. 250 ninja build
    By Drcoop134 in forum Project Builds
    Last Post: 03-04-2016, 10:00 AM
  3. 250 ninja cafe racer
    By Racer X in forum Project Builds
    Last Post: 08-03-2015, 12:11 PM
  4. Ninja 250 or EX500
    By Pete Casper in forum Wanted
    Last Post: 05-27-2012, 10:26 AM
  5. Replies: 35
    Last Post: 02-16-2007, 10:35 PM
Tags for this Thread
