Suzi T500 Cobra Project - Page 6
This is a discussion on Suzi T500 Cobra Project within the Project Builds forums, part of the Caferacer.net Forums category; Originally Posted by TomRacer101 Are you going to use the oil injection ? What system does it have ? Does it lube the crank bearings ...
Page 6 of 7 FirstFirst ... 4567 LastLast
Results 51 to 60 of 66
Like Tree19Likes
Thread: Suzi T500 Cobra Project
  1. #51
    Member Sonreir's Avatar
    Nov 2011
    Albany, OR, USA.
    Quote Originally Posted by TomRacer101 View Post
    Are you going to use the oil injection ? What system does it have ? Does it lube the crank bearings or not?
    Yes, I'm going to be using the injection system. Not 100% about the details of it, but I'm told you don't want to go premix on one of these bikes. Based upon the path of the oil lines, it looks like the bearings may be directly oiled.
  2. #52
    Nov 2011
    Albany, OR, USA.
    Before and (almost) after of the front fender repair.
    Dent removal, welding, and most of the sanding is complete. Still need to buff it and them off to plating. We were originally going to go with chrome plating, but it turned out to be cost prohibitive. We're now going to be doing bright nickel instead. I'm told it requires a little more maintenance in order to keep it looking good, but it's hard to distinguish from chrome as long as you don't let it get too dirty.
  3. #53
    Rome, GA, USA.
    Nickel is beautiful. Looking forward to seeing it plated.
    Nov 2011
    Albany, OR, USA.
    The hardware is back from plating. New zinc.
  6. #55
    Nov 2011
    Albany, OR, USA.
    Crank back from Bill Bune. New seals and o-rings. Bearings checked out OK and lubed up.
    Tanshanomi likes this.
  7. #56
    Jan 2007
    Wharton, NJ, USA.
    Quote Originally Posted by Sonreir View Post
    Looks good. Bill does good work! I assume you will add the oil mod to allow 1400ccs while you have the crankcase open?
    Also feel like I should mention all the goodies Nova Racing Transmissions sells for the T500 - straight cut primaries, billet clutch basket that uses easier to obtain Honda friction plates, close ratio 5 and 6 speed gearboxes. Exchange rate on the Brit pound is the lowest I've seen in a long while.
  8. #57
    Nov 2011
    Albany, OR, USA.
    Yup. Oil dam modification already purchased and ready to install once I get the rest of the cases back. No messing about with the transmission on this build, though. Trying to keep things stock, more or less. Going for more a restomod, OEM+, kinda thing.
    While I'm waiting for parts to arrive, I polished up the domes.
    CaTacL1sm likes this.
  9. #58
    Sep 2009
    Kansas City
    I didn't think the oil dam was still available...or is someone other than Suzuki making them now?
  10. #59
    Jan 2007
    Wharton, NJ, USA.
    Quote Originally Posted by Tanshanomi View Post
    I had an NOS one I loaned to a guy in Tennessee that had repros made. Clauss Studios was the place that made the repros. Now they sell them direct:
    Suzuki
  11. #60
    Sep 2009
    Kansas City
    Very cool. Good job!
  1. Ancient newbie's new '81 Suzi GN400
    By sadarthur in forum NEW MEMBERS READ HERE!
    Last Post: 09-24-2014, 04:48 AM
  2. Suzuki T500 Titan cafe racer project
    By Titan Performance in forum Project Builds
    Last Post: 02-17-2011, 10:23 AM
  3. Good use of a suzi triple
    By Geeto67 in forum General
    Last Post: 01-21-2011, 06:45 AM
  4. Suzi manual?
    Last Post: 04-13-2010, 08:38 AM
  5. Suzi 74 gt550
    By DSstroker in forum General
    Last Post: 09-06-2008, 04:31 PM
