Suzuki Gr 650 cafe my first project
This is a discussion on Suzuki Gr 650 cafe my first project within the Project Builds forums, part of the Caferacer.net Forums category; Hi all, I'm recent member of this forum from Italy. I started recently my first project, I bought a Suzuki Gr 650 and in the ...
Results 1 to 8 of 8
Like Tree3Likes
  • 3 Post By Stephen J
Thread: Suzuki Gr 650 cafe my first project
    Junior Member 20730's Avatar
    May 2017
    Hi all,
    I started recently my first project, I bought a Suzuki Gr 650 and in the free time i modify that at my home. I'm a student and in the weekend I work but I try to do everything at home and buy less possible.
    I really love motor bike and all around engines, in this forum I watch very beautiful projects and a lot of good ideas!
    I post photo of my work in progress, I hope you like it.
Size:  2.07 MBName:  20170616_171638.jpg
Size:  1.83 MBName:  20170619_153059.jpg
    Hope in valuable advice,
    best regards!!
    Mar 2016
    You really should have come here before you started cutting up your frame.
    It looks to me that you have burned through the tubing where you've installed the flat brace at the rear and there is always a question of tire clearance when you replace raised braces with flat ones. It also appears that you have not internally reinforced the tubing where you have cut and welded in your modification, the tubing doesn't line up in some cases and the welding itself looks questionable. Remember, your life depends on the quality of the work.
    You did not see any of the real experts (of which I'm not one) here chop up a bike in this manner.
    Rome, GA, USA.
    Oh, jeeze.
    Jul 2015
    Ontario Canada
    I liked the first picture the best.
    drgonzo, woodsman and BigAl8295 like this.
    May 2017
    Thanks for your reply, for me is a point of start for see things from another point of view.
    To answer you I would like to specify some points you mentioned,
    the tubing where I installed the flat brace it isn't burn but I have installed one extension to raise the frame, it is a piece with a double centering made by lathe. About the welding, the project is now under costruction and I never finish the work, the frame is just pointing.
    In my country unfortunately we can not make some modifications, we must keep the original tubes of the frame and at the limit change some corners.
    Secondly I will finish the welding and prepare for the painting.
    Mar 2016
    Quote Originally Posted by Giammi View Post
    If what you say is true why did you remove the pictures?
    May 2017
    I just changed the last picture because I think it's better in perspective but I'm not practical about this forum and took a lot of time to sort the photos, sorry
    Ews
    Ews is offline
    Senior Member Ews's Avatar
    Jun 2015
    Lewiston Idaho
    I think it looked great as original... why ruin a good thing?
  1. Suzuki SB200 Cafe Racer Project - Exhaust
    By daniels514 in forum Technical
    Last Post: 04-11-2017, 01:36 PM
  2. Suzuki LS 650 as cafe racer?
    By Dones87 in forum Technical
    Last Post: 02-26-2016, 10:58 AM
  3. Suzuki GN400 cafe project
    By Cruisin Dave in forum Project Builds
    Last Post: 09-22-2011, 11:16 PM
  4. Suzuki T500 Titan cafe racer project
    By Titan Performance in forum Project Builds
    Last Post: 02-17-2011, 11:23 AM
  5. 1976 Suzuki GT380 - cafe project
    By eithr in forum Project Builds
    Last Post: 04-26-2010, 09:15 PM
suzuki gr 650 bobber ideas
suzuki gr 650 rahmen
Tags for this Thread
