Guzzi V50 - Page 9
Guzzi V50
This is a discussion on Guzzi V50 within the Project Builds forums, part of the Caferacer.net Forums category; Originally Posted by brad black how did the job cost vs actual resale value ratio work out? The job cost £3800 in total. Not really ...
Page 9 of 10 FirstFirst ... 78910 LastLast
Results 81 to 90 of 91
Like Tree7Likes
Thread: Guzzi V50
  1. #81
    Senior Member steveo's Avatar
    Oct 2013
    Colchester, England
    Not really sure on value, but I've seen a few listed on ebay for £3000-£4000. There's currently a restored one there which is up for £4995.
    https://www.ebay.co.uk/itm/MOTO-GUZZ...0AAOSwqXJbaqSR
  2. #82
    Nov 2014
    Melbourne, Australia
    good work.
    i think investment grade is drawing a pretty long bow.
  3. #83
    Member YallCrazy's Avatar
    Jul 2018
    Quote Originally Posted by CaTacL1sm View Post
    I hate the paranoia that something is vibrating loose. That went away when I got a bike that was drilled for safety wire. The peace of mind is amazing
    The Guzzi has perfect primary balance and the heron headed 30 inchers are docile as Briggs and Strattons without major work. They are nearly as smooth as an electric motor and seldom ever shake anything loose or suffer the first harmonic fatiguing or breaking things.
    Top shelf work steveo
  6. #85
    Aug 2012
    grants pass, OREGON, USA.
    i wanted one of those when they came out ,fantastic work you have done making it new again steveo
    with a dry master cylinder
    i don't even attempt a brake bleed anymore without bench bleeding the master then bleeding it at the banjo
    my own rule : use only brake fluid from a container that has been untouched for a few hrs minimum
    a shaken or jostled bottle has bubbles that can possibly be an issue
  7. #86
    Oct 2013
    Colchester, England
    Thanks for the comments chaps...Much appreciated.
  8. #87
    Oct 2013
    Colchester, England
    Had a phone call from the owner a few weeks ago, she asked me to take a look at the V50.
    The last time she'd ridden the bike was to take it for it's MOT (which it passed), and everything was fine.
    She tried starting it a few weeks later and it basically went bang.
    Anyway finally had a chance to take a look yesterday, think it's fair to say that the engine's toast.
    Only good thing is that the bike wasn't being ridden at the time.
  9. #88
    Senior Member JackC's Avatar
    Oct 2006
    Oneonta, NY, USA.
    Wow! What would have caused that? I have a V50III, sure would not want to see that happen.
  10. #89
    Oct 2013
    Colchester, England
    Quote Originally Posted by JackC View Post
    From what I can see a Con Rod has come off the crank, no idea why the clamp should fail tho.
    I found this post about a V11 with a similar issue, so it's not the first time that it's happened. https://www.v11lemans.com/forums/ind...ine-breakdown/
  11. #90
    Boom!
    that sucks
    and ya imagine throwing both rods at speed on a 4 lane highway, that could be scary.
  1. Replies: 1
    Last Post: 05-27-2017, 02:17 PM
  2. Anyone have info on this Guzzi?
    By drgonzo in forum General
    Last Post: 01-02-2014, 04:43 PM
  3. Windshield for Guzzi V50
    By JackC in forum Wanted
    Last Post: 11-03-2013, 01:43 PM
  4. What do you know about Moto Guzzi V50??
    By JackC in forum General
    Last Post: 06-16-2013, 03:05 PM
  5. New Guzzi
    By Dart7383 in forum General
    Last Post: 11-10-2007, 09:46 AM
