Upgrade front brake caliper
This is a discussion on Upgrade front brake caliper within the Project Builds forums, part of the Caferacer.net Forums category; I see RD400’s with an adapter plate and different caliper..... I also see them with forks from another model motorcycle, in which as different rotors ...
Results 1 to 2 of 2
    Junior Member Funbilly74's Avatar
    May 2018
    I also see them with forks from another model motorcycle, in which as different rotors and caliper.
    Can anyone give info on what caliper adapter is used? Where to get one etc. also what forks can be used and swapped out with??
    Thank you in advance!!
    Here's one with an R1/6 caliper:
    Really, you could make anything fit if you have access to a CNC to make an adapter plate. The biggest issue with 4 piston calipers is the inner side of the caliper can foul the spokes. With a mag you can trim these down as well as shaving some of the caliper. You could also get a more offset disc if there is room.
  1. 77 RD400 front brake upgrade
    By Funbilly74 in forum Wanted
    Last Post: 05-30-2018, 01:08 PM
  2. Front Brake Caliper 75 CB550
    By bukaman in forum General
    Last Post: 07-30-2017, 04:03 PM
  3. OEM+ Twin Piston Brake Caliper Upgrade For SOHC CB750F
    By jaguar in forum Tips and Tricks
    Last Post: 06-22-2016, 02:14 PM
  4. Front brake upgrade???
    By Mr.G in forum Technical
    Last Post: 04-22-2016, 07:49 PM
  5. help with front brake upgrade on cb750
    Last Post: 07-05-2007, 02:32 PM
rd400 front brake upgrade
yamaha rd400 front brake kit
