CB400T Shitbox Build - Daily Driver - Page 17
This is a discussion on CB400T Shitbox Build - Daily Driver within the Project Builds forums, part of the Caferacer.net Forums category; Got so carried away with my suggestion for your clutch lever problem, I forgot to comment on your built. Sweet. I'm sure it will turn ...
Page 17 of 17 FirstFirst ... 7151617
Results 161 to 169 of 169
Like Tree51Likes
Thread: CB400T Shitbox Build - Daily Driver
  1. #161
    Member peter400four's Avatar
    May 2014
    Launceston, Tasmania, Australia
    Got so carried away with my suggestion for your clutch lever problem, I forgot to comment on your built. Sweet. I'm sure it will turn a few heads when you ride down to the Spinne Brueke on a sunny Sunday for a cup of coffee and a Currywurst.
  2. #162
    Member jakejensen's Avatar
    Sep 2018
    Berlin
    Managed to get the bike out of the bomb shelter. I’m pretty disappointed in the paint job though. The fairing ended up a completely different color than the tank. I used the same paint but what a difference, especially in the flat light. Only thing I can figure is the tank didn’t get primed grey before the silver paint went on. I’m going to hold off on the livery and try to get the tank to match the fairing.
    Also ordered a new tachometer which will be here soon. This old gal is SCREAMING when I hit 4th gear haha...
  3. #163
    Sep 2018
    Berlin
    I picked up an entirely new instrument cluster for the bike. The old tacho sounded like this before I replaced it.....
    What's that noisy chainey sound you ask? Balancer chain adjustment needs more attention still. I adjusted it down, but now the adjustment swingarm is maxed out and the balancer chain still makes hella noises, I've attached a photo looking into the case through the right side cover.
    I did some reading on the HondaTwins forum, and it sounds like you can re-tension the balancer chain tensioner spring (effectively re-setting the tensioner swing arm) but it needs to be done carefully. There is a small punch mark made on the end of the balancer chain adjuster and it should be between 3 o'clock and 9 o'clock. If it gets past 9 o'clock the balancer chain must be replaced. I peeked through the right side cover and it my balancer chain adjuster has the punch mark just above 3 o'clock currently. I will have to drain the oil and pull the cover to make this adjustment.
    I also got my new R/R in the mail, so that will go on this week as well as the Lithium Ion battery. This will round out some of the electrical upgrades - blade fuses, upgraded Regulator/Rectifier, and lithium ion battery.
    I (hopefully) will pick up the seat tomorrow as well!
    Sep 2018
    Berlin
    The bike is at a stopping point for now. Here is the before and after, until I can fix the paint and put the livery on it.
    Got it out tonight and drove it around a bit. Can’t wait to get back and start riding it daily!!
    Im headed out of town for a month or so. Until I get back it’s gonna be stored in my apartment, because I don’t really have another secure place to put it haha.
    So until May it’ll be chilling in my living room
  6. #165
    Mar 2016
    It's a moped to motorcycle transformation. It would be easier to match the darker paint and the colours in the decal kit will work. To remind you of evil Cafe Racer wannabe you once were, you should ride "The Freddie Dark Roast".
    jakejensen likes this.
  7. #166
    Sep 2018
    Berlin
    Loool, Freddie Dark Roast. What's more hipster than batch roast coffee? Oh yeah, mircro brewed beer.
  8. #167
    Mar 2016
    Quote Originally Posted by jakejensen View Post
    Fucking Hipsters...they can't have it both ways, they're either cafe racing or bar hopping. How 'bout ....Freddie's Dark Brew, that would get you in with waste land wannabes as well.
  9. #168
    Sep 2018
    Berlin
    Now we're cooking with grease. I'll do you one better, so we don't leave out the wannabe lumberjack "beard implant" fucks in the NorthWestern US........ Freddies Dark Brew Autumn IPA
  10. #169
    Mar 2016
    A dark brew pale ale sounds to hipster.
  1. My new daily driver
    By kenessex in forum Project Builds
    Last Post: 06-09-2014, 10:09 AM
  2. Texas daily driver
    By Geeto67 in forum General
    Last Post: 04-10-2012, 02:41 PM
  3. Should this be my new daily driver?
    Last Post: 02-02-2011, 04:43 PM
  4. 8yr old rally car driver - not bad
    By kerosene in forum General
    Last Post: 04-23-2010, 09:54 AM
  5. Shitbox Cars
    By dreamqueen in forum General
    Last Post: 02-16-2010, 09:15 PM
