Yamaha xj900p 2008
This is a discussion on Yamaha xj900p 2008 within the Project Builds forums, part of the Caferacer.net Forums category; Originally Posted by kumailrashid
I have not cut the supports for the shock I only edited the pic. I will finish it and won't be ...
7Likes
Member
kumailrashid
I have not cut the supports for the shock I only edited the pic. I will finish it and won't be for sale. I'll let you guys know it goes
Attachment 97769
What I believe they are trying to tell you is that the tubes that you cut off were what was holding the frame and shock mount in square. The proper way to modify a structural member is to put your new stuff in before cutting off the old so that the frame doesn't torque out of place when you cut off the old. To demonstrate this, if the piece you cut off is still in one piece see if it would line up if you wanted to weld it back in place. I've got no motorcycle frame experience, but that is what you would need to do before modifying a truck frame.
At a minimum you need to tie those cut tubes into your structure above so that when you hit a bump it doesn't rip that shock mount off or just bend the whole upper works upward.
Junior Member
Okay i just work differently. so im going to remove totally the top bar and bottom bar and move the shock on the top of the swing arm like in the XJ600
weld the shock top mount under the tank. might need to change the shock depending on the distance i need
Junior Member
i hope this makes sense to you all n im on the right path. would like to know would the stock do or can i use the XJ600 rear shock
Senior Member
Well, what have you found out so far when you studied the geometry of what you want to do?
Certainly you've put more thought into it than just cutting and pasting jpgs on each other before asking if it will work?
Senior Member
kumailrashid
actually, you're kind of working like most people who come here with ideas that aren't based too heavily in reality. we see a lot of them.
if you think it through and do it right it is possible.
Senior Member
Isn't the 600 a chain drive?
Junior Member
Yea i have measured up and checked the angles it should work. im having my friend do it in CAD n let me know
Junior Member
Yes 600 is chain drive and my is shaft i will not be changing the swing Arm but simply creating the same style shock mount to be able to mount the shock on top of my swing arm.
Senior Member
kumailrashid
Is this your real live bike and does it have a linkage type monoshock suspension?
& is your plan to turn it into an inferior non-linkage type suspension?
if yes ... that's a really bad idea dude :|
Senior Member
TrialsRider
I don't believe the OP will have any idea what your talking about.
- You may not post replies
- You may not edit your posts
Forum Rules
Last Post: 05-04-2010, 11:49 AM
By imslow in forum Bikes For Sale
Last Post: 03-20-2010, 12:28 PM
By texmawby in forum Vintage Motorcycle Racing
Last Post: 10-24-2007, 01:03 AM
By ROSKO in forum Vintage Motorcycle Racing
Last Post: 10-16-2007, 07:13 PM
By ROSKO in forum General
Last Post: 10-04-2007, 10:38 AM
Tags for this Thread
