KZ750 project - Page 7
KZ750 project
This is a discussion on KZ750 project within the Project Builds forums, part of the Caferacer.net Forums category; Not the end of the world, a machine shop can enlarge the hole to 190 AND fix the stripped thread...
Page 7 of 8 FirstFirst ... 5678 LastLast
Results 61 to 70 of 73
Like Tree9Likes
Thread: KZ750 project
  1. #61
    Feb 2009
    Fort Knox, Kentucky
  2. #62
    Member Oldjeep's Avatar
    May 2019
    190 refers to the spacing between forks. The thing costs $104 brand new, no point in machine work.
  3. #63
    jcw
    jcw is online now
    Senior Member jcw's Avatar
    Jul 2015
    chicago burbs
    Quote Originally Posted by Oldjeep View Post
    That sucks donkey balls. Sorry.
    Just to make you feel better, I think I might have run my practically newly rebuilt aprilia engine without oil for about 5 minutes. I win the stupid contest.
    Honey, where's the Bactine?
    Nov 2008
    Need picture not price lists. The stripped thread is easy fix, 'too short' hmmmm, not so easy depending on wall thickness though it's do-able, 2.5mm either side
    Ouch,four stroke, plain bearings will be scrap, two stroke meh, no bigge
  6. #65
    May 2019
    Quote Originally Posted by crazypj View Post
    Yes, the stripped thread is an easy enough fix. Changing the spacing would require a precision cut/drilled piece of billet aluminum to replace the bridge section. Not sure what you are talking about wall thickness for, there is no way to machine this wider.
  7. #66
    May 2019
    Hopefully there was a lot of assembly lube. I've run a couple jeeps upside down and they have survived a couple of minutes of no oil pressure, so maybe you get lucky?
  8. #67
    Nov 2008
    Oh, it's the 3 piece one! piece of piss to make a new centre section, doesn't even look like the high dome version for 19" wheels I guess it's the engineered plastic? Wall thickness refers to how thick the pieces are that clamp to fork top. If thick enough you can offset bore so finished size will just about 'witness' on the inner piece but the outer will be 2.5mm thinner. That actually isn't a high precision piece, it relies on clearances between pieces tp line up properly. You probably have +/-0.005" tolerance on bolt holes at at best +0.005" / -0.002" on the fork clamps
  9. #68
    May 2019
    It is all aluminum and the bridge section is raised not flat. Quite honestly it doesn't matter any more. If I want to run the twisty roads I'll use the Yamaha FZ1 I bought last week.
  10. #69
    You should get those funky headlights that look like they are staring at you:
    would scare the hell out of dogs and small children, keep them out of your way
  11. #70
    May 2019
    LOL, what do they call those owl eyes? I think the only additions on my list are a set of givi side bags and a taller windshield
  1. 1980 kz750 ltd-h1 project
    By kzpappy in forum Project Builds
    Last Post: 11-07-2013, 03:16 PM
  2. KZ750 project an question
    By MikesChevelle in forum Project Builds
    Last Post: 11-15-2011, 06:41 PM
  3. Tell me about the KZ750 twins!
    By coolatula in forum General
    Last Post: 01-14-2008, 06:38 PM
  4. Newbie with a KZ750 twin
    By Matt Tobias in forum General
    Last Post: 08-31-2007, 12:44 AM
  5. '76 Kawa KZ750 Twin
    By hellfishtat in forum General
    Last Post: 08-16-2006, 11:37 AM
