Ducati Monster S4
Ducati Monster S4
This is a discussion on Ducati Monster S4 within the Project Builds forums, part of the Caferacer.net Forums category; Well I recently bought this "barn find" bike that I will be transforming into my dream bike. Step one is to 100% take it all ...
Results 1 to 10 of 20
Like Tree4Likes
Thread: Ducati Monster S4
    Senior Member jaguar's Avatar
    Dec 2005
    Albany NY
    Ducati Monster S4
    Step one is to 100% take it all apart.....
    Oh.....wait.
    So the board has been rather slow these days, figured I would track some of the progress and stories of the new bike here.
    Before my wife and I bought our first house about a year ago I sold off most of the vintage bikes.
    This spring I started casually looking for something to ride to work and bomb around upstate NY on.
    Looked at a million different options, but kept coming back to a Ducati Monster.
    Then as luck would have it I stumbled across this 2001 S4 at a semi local dealer.
    Seems to be a one owner bike, almost 100% stock, clean an about 9k miles.
    No real plans to "build" anything with it.
    But that isnt to say things will be stock either.
    So far I have put a few hundred miles on it and come to the conclusion the tires need to be changed as the first order of business.
    They have good tread, but are dated 2006 and starting to get hard. I am not a huge fan of how they feel when being pushed. That said I am not actually an overly fast or skilled rider, so it might just be me being a scardy cat.
    Ordered some Michelin Power RS tires for it.
    Also some EBC pads. Figure the fluid needs to be changed and I might as well swap out the pads.
    Bought some stock mirrors as I am not a fan of the bar ends.
    I am sure I will track down some little carbon ad ons here and there as well.
    There is no record of a belt that would be "in time", but I checked the one on the motor now and it looks/feels perfect.
    Have the tools to change it, but probably will not bother this season.
    Maybe if the fears of the flaking rockers gets to me first.....
    One project I do want to take on is the suspension. Would like to rebuild/upgrade it.
    Never had a performance bike tailored to me, and think that would be fun and interesting.
    Suggestions?
    CaTacL1sm, Geeto67 and jcw like this.
    I am Derby\'s Bitch
    Feb 2009
    Fort Knox, Kentucky
    I know Race Tech builds custom shocks, if you don't want to go with the "common" ohlins upgrade
    Senior Member nic579's Avatar
    May 2010
    Start with a sawsall cut the seat off
    I believe in the 2 year belt plan o matter what they look like.
    I have fount even on a new bike proper oil change and level often transform the bike.
    Next I would go race tech and quality rear shock + spring/s weight/sags and or fork internals kit
    jcw
    jcw is offline
    Senior Member jcw's Avatar
    Jul 2015
    chicago burbs
    I like the guys at Traxxion Dynamics
    They have a rear shock revalve and respring service that they will customize to your weight. On the front they offer their own in house rebound and compression valves. I'd DIY it (install them myself), but on their website they say it's a send in service only. Probably requires a bunch of specialized tools anyway. They can respring the forks and set the air gap, and clean, sand and debur the tubes. Your forks will literally be better than new. They also check for straightness, too, so don't be too surprised if they say your tubes are slightly bent. They do tube straightening too.
    Looking at the website you are probably in for $1000+... But like I said, your suspension will be better than new.
    My brother had a monster. Nearly killed him, on some road in California... good times.
    ... They also check for straightness, too, so don't be too surprised if they say your tubes are slightly bent. They do tube straightening too. ...
    On USD forks? that's a scary thought.
    jcw
    jcw is offline
    Jul 2015
    chicago burbs
    still the steel parts
    The steel parts if any would be the stanchion tubes (although they are now starting to make those out of aluminum alloy as well), any time I bent forks it was always at the bottom of the lower triple tree yoke. I would expect a bend on a USD fork in that same place would be terminal. Plus considering that USD forks are intended to be more resistant to flexing in that area the aluminum outer tube is going to be scrap if it was subjected to crash type impact forces. Scary expensive bits that imply a crash happened at some point in time.
    ... should think you would experience oil leakage, wear marks and binding in the suspension travel if USD forks become bent, no?
    May 2010
    I will say one thing I have never regretted is having a good suspension on the bike you can never under estimate having a properly set up suspension for your bodyweight .
    jaguar likes this.
    Senior Member monkey's Avatar
    hull, mass, USA.
    Jag
    i have a set of pilot power rs takeoffs from last season.
    i go thru a set or two per season doing trackdays
    they are fresh and have tons of tread
    let me know
    yeah im 20 miles south of boston
    latered
    Nov 2014
    Melbourne, Australia
    the forks are the typically flawed short adjuster showa, but can be fixed. you can fit gsxr cartridges or others. there's a bloke i use locally who makes each leg single function.
    does it have a sachs shock? you should be able to get it redone satisfactorily too.
  1. ducati monster parts
    By monkey in forum Wanted
    Last Post: 11-05-2011, 07:44 PM
  2. ducati monster parts
    Last Post: 08-02-2011, 07:48 PM
  3. 2002 Ducati Monster 620, 1977 Suz Gs550 pair...NY
    By anup_vince in forum Bikes For Sale
    Last Post: 03-28-2010, 01:36 PM
  4. to monster or not to monster
    By Brentadour in forum General
    Last Post: 10-09-2003, 08:38 PM
  5. '99 Ducati Monster 750dark
    By Nick in forum Parts For Sale
    Last Post: 04-22-2003, 02:44 PM
