My Ape project - Page 9
My Ape project
This is a discussion on My Ape project within the Project Builds forums, part of the Caferacer.net Forums category; Beats my system of broom handles and hockey tape....
Page 9 of 10 FirstFirst ... 78910 LastLast
Results 81 to 90 of 97
Like Tree20Likes
Thread: My Ape project
  1. #81
    Senior Member Cyorg's Avatar
    May 2014
    jcw likes this.
    "Non urinat in ventum"
  2. #82
    jcw
    jcw is online now
    Senior Member jcw's Avatar
    Jul 2015
    chicago burbs
    Quote Originally Posted by nic579 View Post
    Sold a mill and a lathe and I think that was the case.
    We still get some interesting stuff.
    South Bend Lathe - $1500 (Cheektowaga) hide this posting
    <image 1 of 18
    South bend 9 x 42 Lathe
    3 Jaw Chuck; 4 Jaw Chuck, Steady Rest, Follow Rest, Face Plates, Collets, Toolholders w/ Cutting Bits, Drill Chuck, Live Center, Dead Center, and Other Miscellaneous Tooling
    *Belt will need to replaced but still works
    *Belt cover is cracked
    Email Only. can see anytime between 8-5pm Will respond quickly
    How bout that race?!?!?!
    Dovi pulled a Marquez on Marquez!
    I was watching the replays and he had the brakes on so far past the apex it was insane.
  3. #83
    Senior Member nic579's Avatar
    May 2010
    He pulled a Marques but made it stick. Unlike Marquez seems Dovi Dovizioso'ed Marquez once again. Good to see Dovi no give up today!
    https://www.motogp.com/en/videos/201...nd-prix/304595
    jcw
    jcw is online now
    Jul 2015
    chicago burbs
    I wasn't crazy about the aesthetics, so I redid it.
    Performed about 10x worse than first one... literally. And was about .2kg heavier.
    But, I've got to get moving on this.
  6. #85
    jcw
    jcw is online now
    Jul 2015
    chicago burbs
    Of course, once I started on the subframe, I tend to build the design that requires the least amount of work.
    The 1/8" wall bolt spacers welded to .03" wall tubing was a PITA until I got the heat settings right. So bad that I basically just hot metal glued the first two (upper subframe to frame mounts) and ground the globs of welds smooth. Soooooo lame.
    The last two (lower subframe to footpeg/frame mounts) were much better as my muscle memory came back to me and I understood the heat distribution and intensity better. Welds decent enough to leave unfinished.
    The .03" to .03" tube welding was better. Not my best work. Not great. But solid structurally and passable aesthetically.
    I'm starting out with this. And will add on as needed.
    mounting tabs for the seat pan, rear tank mount, exhaust, and cross braces and extensions for the tailpiece.
    Name:  subframe progress 1.jpg
  7. #86
    Some day they are going to make a subframe out of plastic that is also an air box, rear inner fender, exhaust support and seat support all in one piece, held on by only 4 bolts.
  8. #87
    jcw
    jcw is online now
    Jul 2015
    chicago burbs
    they make them out of carbon fiber...
    i wish you could get a fuel cell made to order in plastic and then cover it with a tank cover in the shape you want.
  9. #88
    jcw
    jcw is online now
    Jul 2015
    chicago burbs
    this is an intresting look...
    Name:  seatpan installed.jpg
    seat pan is on solidly and securely except for a small tongue under the front that I need to fab a corresponding groove on the subframe to lock the seat pan down.
  10. #89
    May 2010
    You could make a styrofoam plug and have it laid up in carbon fiber epoxy, than melt out the foam.
    Looks like it’s coming along.
  11. #90
    jcw
    jcw is online now
    Jul 2015
    chicago burbs
    I've still not tried my hand at fiberglassing...
    It's something I've got to learn.
