My little CB100 - Page 3
My little CB100
This is a discussion on My little CB100 within the Project Builds forums, part of the Caferacer.net Forums category; That was my thought train to. Drilled and tapped a hole, just didn't hold. Couldn't get a good angle on the shaft, so I found ...
Page 3 of 7 FirstFirst 12345 ... LastLast
Results 21 to 30 of 70
Like Tree7Likes
Thread: My little CB100
  1. #21
    Member mitchi's Avatar
    Sep 2013
    Georgia
    Couldn't get a good angle on the shaft, so I found a replacement..........pulled the engine, and went to town...........first time ever going into and splitting an engine.
    Wish me luck......
    "If it ain't raining, I'm riding"~~~~~~{iii}?~~~~~~~prost~~~~~
  2. #22
    Oh my.
    Should have made it a keyway and gone with a better lever, much easier and cheaper.
    ... take pictures of everything you take apart.
  3. #23
    Feb 2009
    Fort Knox, Kentucky
    or just weld the kick lever on...
    Sep 2013
    Georgia
    Quote Originally Posted by CaTacL1sm View Post
    Trust me......seriously considered, till I thought about cleaning the rotor filter out during oil changes.
  6. #25
    Sep 2013
    Georgia
    Well, got the engine rebuilt with new kicker. Reinstalled, and running.
    Been wiring the lights and stuff. Got a cb160 headlight bucket, now need a speedometer to fit in there. (one that works for a decent price)
    Not really worried if the ratio is not the same.
  7. #26
    jcw
    jcw is offline
    Senior Member jcw's Avatar
    Jul 2015
    chicago burbs
    Late to the party, but I would have put a couple spot welds on the outside that you could grind off if you wanted to remove the kick lever.
    But you did the right thing...
  8. #27
    Sep 2013
    Georgia
    Thanks, it was a good learning experience.
    I tore open a CL350 engine at the same time just because I seen a lot of permatex around the edges, and man, what a lot:
  9. #28
    His day job is at waffle house.
  10. #29
    Feb 2009
    Fort Knox, Kentucky
    but did it leak?
  11. #30
    Sep 2013
    Georgia
    but did it leak?
    Ha ha.........never had it filled to know.
    Bet it didn't, but might have been the reason for the fried top end.
