1978 Triumph Bonneville project - Page 4
This is a discussion on 1978 Triumph Bonneville project within the Project Builds forums, part of the Caferacer.net Forums category; Not much to show for 3 weekends of work. Still can't get the swinging arm to budge but got a few parts cleaned up/powder coated. ...
Page 4 of 7 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 64
Like Tree10Likes
Thread: 1978 Triumph Bonneville project
  1. #31
    Senior Member steveo's Avatar
    Oct 2013
    Colchester, England
    Virtually every nut and bolt has put up a fight so far.
    Just a quick question, I've fitted some stainless M6 fixings to the rear mudguard does this mean that I'll burn in hell?
  2. #32
    Member upperb's Avatar
    Feb 2012
    Cabot, PA
    There should be someone here that can direct you where to request a special dispensation.
    steveo likes this.
  3. #33
    Junior Member dr.blom's Avatar
    Oct 2018
    No, but edward turners ghost will haunt your dreams until you put the correct unified fastener there
    steveo likes this.
    Senior Member Mark Burton's Avatar
    Jan 2014
    Midlands UK
    M6 .......nooooooooo, you need to go over to the Dark Side and fit Imperial
  6. #35
    Oct 2013
    Colchester, England
    A little bit done today. Got to 2 o'clock and couldn't be arsed to do any more...Time for some beer.
    Mark Burton likes this.
  7. #36
    Senior Member Cyorg's Avatar
    May 2014
    Take a good look at the area around the swingarm and down tube. If that one was cracked badly you’d know it by now. If I understand correctly, it was the early ones that were more likely to have the problem. Anyway.... better to look now just to make sure.
    https://www.triumphrat.net/classic-v...-oil-leak.html
    Have you been soaking the swingarm pivot bits? I should really take my own advice and go see if I can pull my swingarm spindle without any drama.
    "Non urinat in ventum"
  8. #37
    Oct 2013
    Colchester, England
    Thanks for that Cyorg, the frame looks fine.
    Thought I'd sorted the swinging arm this morning. The pivot had been soaking in acetone/ATF for a week, so tried turning it with a large torque wrench and it finally started moving.
    Still can't knock the bloody thing out tho, so looks like I'll have to go with plan E and give the frame to someone that knows what they're doing.
    Spent the morning degreasing the frame inside and out, things got a bit messy. Don't know why the missus got so upset, I gave her washing up bowl a quick rince before handing it back.
  9. #38
    Oct 2018
    If its turning the hard part is over, now just add more heat and penetrant get it up to 350 degrees celsius and it will come out with a few knocks.
  10. #39
    Oct 2013
    Colchester, England
    Quote Originally Posted by dr.blom View Post
    Cheers.
  11. #40
    Nov 2014
    Melbourne, Australia
    i don't know that i could have resisted the temptation to just beat the living shit out of it this long.
    dr.blom likes this.
