Father's day gift Honda CB350 Build - Page 2
This is a discussion on Father's day gift Honda CB350 Build within the Project Builds forums, part of the Caferacer.net Forums category; Two strokes need to be jetted richer at WOT at high revs compared to a 4 stroke. A 4 stroke also needs to have the ...
Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Like Tree3Likes
Thread: Father's day gift Honda CB350 Build
  1. #11
    Senior Member Teazer's Avatar
    Mar 2010
    , IL, .
    Two strokes need to be jetted richer at WOT at high revs compared to a 4 stroke. A 4 stroke also needs to have the fuel flow broken up into smaller droplets to burn efficiently. A primary type needle jet achieves those for a 2 stroke and an emulsion tube (bleed) type does what's needed in a 4 stroke, but it needs much smaller main air jets.
    So to use a carb set up for a 2 stroke on a 4 stroke might work, but it's not doing its best work. Change air jets and needle jets and you start to get closer.
    Honda and their Keihin carbs used an oval venturi so that at small openings, it was like have a smaller carb and ass the slide rose, the overall area of the tall, narrow venturi was the same as a bigger sized carb. So they work great at small throttle openings and still work well at higher loads.
    K0 carbs are better than K1 on because they take individual cables, but the top caps from a later model can be adapted. I used CB750 carbs on my Methanol burning 350cc CB77 racer for years.
    XB33BSA likes this.
  2. #12
    Junior Member pappavol's Avatar
    Jul 2019
    Quote Originally Posted by upperb View Post
    I would encourage you to take everything that XB is willing to share on the subject of Honda twins as gospel. Read his posts and watch and listen to his videos of him riding his 350. It revs quickly (owing, in large part to his having lightened the crankshaft-and maybe the rotor/flywheel), pulls strong and carburets cleanly. I think that it would be very difficult to plumb his knowledge on this subject, which knowledge he shares freely.
    I understand and appreciate the need to separate the wheat from the chaff when considering advice, especially from internet “experts.” However, I think that you will soon learn that there are some folks on this forum who bring a lot of real world, useful knowledge, gained from professional shop time and years of racing, tuning and being part of other aspects of the industry, to discussions held here.
    I also appreciate the desire to see if one can “find the key” to making something work (e.g., Mikuni VMs on your bike) that has been tried, in the past, without success, by engineers, tuners, racers, etc., or unleashing “hidden” power from an engine that has had huge amounts of development time and money already devoted to it. Looking back, I think that I would be hard pressed to think of an occasion where I was able to do so. (Applying new technology to an engine that has had thousands of hours of development time put into it already, e.g., adding electronic fuel injection, is, of course, another story.)
    All of that said, unless you have very little experience in building and tuning engines, are looking at this project as a learning experience and are willing to spend the time and money learning why others were unable to make a particular combination work, I would encourage you to take the advice of those who have gone before you and (truly) figured out what works. There are a number of such folks here.
    Good luck and welcome aboard. I wish I could have back some of the time and money that I spent trying to make things work that others with knowledge superior to mine told me would not.
    This is my first build so yes I am rookie, trust me I try to absorb everything I can. If these carbs don't work I will be referring back to this thread for XB's advice. Hopefully I will be to the tuning stage soon.
  3. #13
    Jul 2019
    This weekend I discovered that I got the blinker wires a little to hot causing them to melt while using shrink tubing. I was able to get the front of the bike wired, and built the battery box.
    Next I will be fitting the rear fender and the seat, then wiring up the rear of the bike. so hopefully I will be tuning the bike by the end of the month.
Size:  4.30 MBName:  IMG_3440 (1).jpg
    Quote Originally Posted by pappavol View Post
    I think they will work good enough if everything else is working good. But I'm an optimist
  6. #15
    Junior Member GRAVEL RASH's Avatar
    Mar 2019
    Individual air filters and CV carbs can be awkward to set up, i had them on a XS650 i had.
    I tried a few different pilot jets and mains in those old mikunis but it was never as smooth as with the air system on.
    I made a air chamber from a old round lawnmower tank and one 54mm air filter. it ran great like this, and looked better than it sounds too.
    Cv carbs need that air chamber space to let them work properly.
    TrialsRider likes this.
  7. #16
    Aug 2012
    grants pass, OREGON, USA.
    Quote Originally Posted by Teazer View Post
    i think i learned more about the differences in carbs reading what mister teazer has posted over the years than what i had till then
    main reason is it makes sense
    another thing not mentioned above but teazer opend my eyes to it is the path of fuel air mix is so much different on a 2 stroke
    on a 2 stroke the mix is compressed twice (as well as being sprayed onto a rotating crank and rod)
    the first staige of charge compression is what allows the mix to take the long path up stairs and it needs to be an somewhat energetic blast to maintain velocity up through the transfer ports and continue on loop charging the combustion chamber
    loop charging is what was a revolutionary change in 2 strokes
    and i remember very interestingly reading about it
    as me dad had just got a brand new 50 hp twin evinrude for our little 14ft ski boat
    and it had loop charging
    no longer were 2 strokes going to realli on a hideously large shaped in a grotesque manner piston crowns in order to get the then straight shot transfer charge to change direction go up then down to chase the spent gasses out the ex port
    loop charging meant pretty much flat top pistons and a simmetrical comb chamber with squish bands that can be fully effective
    so the 2 stroke charge is really heavilly manipulated and hence a fine atomization is not nuber one
    with the weaker signal just getting the gas in there is more important
    4 stroke has a very stroing intake puls and it lasts longer in degrees of crank rotation than 2 stroke pulse
    4 stroke has the charge exposed to lots of cylinder wall surface area
    but it is simply dumped into the cyl the compressed with some vigourus mixing happenning when the squish gap closes up
    if the charge is not fine enough
    if it is to close to having droplets fall out of suspensinon then tmy thinking but i cannot provre it and have nevert read about it
    but maybe too much fuel as liquid sticks to the cyl walls wetting them
    anyway the other deal is the mikuni oem and keihin 4 stroke carbs all have a smaller inlet and vare using a stack to get a designed tuned intaske port length mn
    and the mikuni designed for 4 t all have a tall oval variable venturi
    the amals and del orto's do not but dells went to flat slides and they and amal have provision for proper stack design attatchement
    the mic 2 t carbs have a huge bell mouth right there so to get a decently long intake port the carb needs moving away from the valve seat as a vstack wont be able to blend flow at that bell moiuth
    there is prejetted this and prejetted that
    but i looked at the sohc 750 and the only real diff to a cb350 is each 750 jug is 10cc's or so bigger
    otherwise a simply 2 valve design
    and trhe first xl175 is basically a cb350 cut in half and it uses same style keihin
    honda put huge amounts of research and dyno testing developing these carbs with keihin
    you look at them then look at a vm mikuni which was nevert meat to be used on 4 sdtrokes
    and you see huge differences inb the design but still go trhe vm path ?
    the dime skittle cycle parts prejetted route lol
    and the sl350 twin uses an exact same design carb as the750 c albeit 4mm smaller (the sl port is 4-5mm smaller than a cb as well)
    logic dictated that the 750 carb had to work perfectly on the cb350
    and it does
    i have fiddled with needle positions and mainjet but basically it runs perfect with no changes from the 750jetting specs
    interestingly the 24mm sl carb and the 28mm sohc 750 carb y use same 120 main
    and same pilot jet size
    same slide cutaway number same float level etc
    i know an accel pump can be a desirable feature but i feel 350 with the 2.2 lbs shaved offv the crank doesnt need a pump
    its not like you are going to try to whack the throttle ope at 4k rpm anyway
    here is a short shit vid of the beast
    at
    but nether is a hard whack to wot it really comes alive and responds even better
  8. #17
    Mar 2019
    The Conventional carbs are a easier option to tune, with the CV carb the way they work you have a lot to take into account when tuning them.
    The stock air boxes have the volume and filtration along with exhaust back pressure all worked out to meet emissions and run at or very close to optimal when they leave the factory.
    CVs have real potential to play up as soon as you disturb anything, I imagine if you have a drawer full of springs needles main jets and pilot jets you might hit gold with oipen pipes and pod filters.
    But sticking with the stock airbox or a home made box with similar characteristics will save a lot of time and frustration in the majority of cases.
