Bimota SB6R - Page 3
Bimota SB6R
This is a discussion on Bimota SB6R within the Project Builds forums, part of the Caferacer.net Forums category; Originally Posted by Cyorg So Venhill said yes? Yeah, it is really isnt that expensive either. Probably means I will not ride it this season ...
Results 21 to 30 of 39
Like Tree12Likes
Thread: Bimota SB6R
  1. #21
    Senior Member jaguar's Avatar
    Dec 2005
    Albany NY
    Probably means I will not ride it this season though based on time line.
    Im okay with that though.
    I am Derby\'s Bitch
  2. #22
    Dec 2005
    Albany NY
    Finally got some time to mess with the carbs.
    Gaskets were perfect. Nice price and killer quality. Super happy.
    Saw a deal on some JIS screw drivers a while ago, and this is the first time I get to use them!
    Funny that it was on a Bimota, and not my normal garage of Hondas
    Pro tip while rebuilding carbs.
    Always use a spill proof glass for your drink....
    All ready to go back on.
    Ran into one small issue.
    When putting the float bowls on, I assumed that I had mixed up the order, as the drain was not pointing in the correct direction.
    I "corrected" this, but found out I was wrong when I went to install the carbs.....
    The drain hits the shock mount.
    Gotalove this stuff.
    I am Derby\'s Bitch
  3. #23
    Nov 2014
    Melbourne, Australia
    Quote Originally Posted by jaguar View Post
    that would be a bimota.
    Dec 2005
    Albany NY
    Yup.
    but the simple swapping of bowls around gets everything tightly packed in here.
    better then having some one off carb that you can't service
    I am Derby\'s Bitch
  6. #25
    You'd have lots of clearance if those were fuel injection throttle bodies instead of CV carbs
  7. #26
    Dec 2005
    Albany NY
    But way less fun!
    I am Derby\'s Bitch
  8. #27
    Senior Member nic579's Avatar
    May 2010
    Looks very familiar.
  9. #28
    Dec 2005
    Albany NY
    Quote Originally Posted by nic579 View Post
    Oh yeah?
    Did you know the bike/seller?
    I am Derby\'s Bitch
  10. #29
    Dec 2005
    Albany NY
    Bike moved under its own power yesterday!
    Got everything buttoned up and it fired right up.
    Took it to get fuel and was great.
    Tried to take it on a quicker blast to open her up a bit and failed.
    Seems to be starving for fuel.
    Suspect the silly vacuum fuel pump thing, and a bad filter.
    Changed those last night, but was too late to take a road test.
    Put a couple of miles on it hoping in vain that it was just a slug of bad fuel or something.
    Name:  Bimota After.jpg
Size:  3.87 MBName:  Mileage.jpg
    jcw likes this.
    I am Derby\'s Bitch
  11. #30
    Senior Member Cyorg's Avatar
    May 2014
    Can you translate par. 8.4 into the queens english?
    "Non urinat in ventum"
