Battery relocation on an ST3 Ducati
This is a discussion on Battery relocation on an ST3 Ducati within the Project Builds forums, part of the Caferacer.net Forums category; I recently acquired a 2004 ST3. Good news is that all that plastic bodywork protected the hard parts. You can deduce what the bad news ...
Page 1 of 3 123 LastLast
Results 1 to 10 of 26
    Senior Member Teazer's Avatar
    Mar 2010
    , IL, .
    I recently acquired a 2004 ST3. Good news is that all that plastic bodywork protected the hard parts. You can deduce what the bad news was.
    So the plan is to turn it into one of those fancy Cafe Racers that I keep reading about. The frame is more or less straight and forks and wheels are fine. Front (bald) tire has just been replaced along with broken bar and clutch reservoir. I did have ideas on keeping the stock headlamp and upper half fairing but that's missing at least half of the plastic and I can't be arsed molding and shaping foam to rebuild what's left and changing the shape.
    So we are going naked - the bike not me and that's leaving all sorts of bits hanging out in the breeze making it look untidy. Brad Black has been incredibly helpful already pointing out some pitfalls in my ideas and generally keeping me pointed in the right direction.
    The front cylinder coil has been relocated under the airbox already and I will have to hack a pound of copper out of the wiring loom to simplify it. I think I can relocate the ECU and Regulator/rectifier to the space previously occupied by the front toolbox but I may need to fit an early Monster oil separator tank to get the shape right. I can re-locate the fuses and relays that sit on the stock undertray.
    That leaves me with two issues to resolve. First is whether to remove the lower rear frame and make it more like an early monster to appear higher and cleaner at the back end, and the second is relocating the battery. Not enough space under the tank without cutting and welding the tank or fitting a 999 or 1098 tank and that's not in the budget. Who am I kidding there is no budget.
    Ayy thoughts on battery relocation? I hate putting all that weight in the tail, but can't see anywhere else to stuff it. All ideas appreciated.
    Senior Member nic579's Avatar
    May 2010
    I had a 92 GSXR 750 with a battery pasted to the counter shaft cover "tiny battery" in a nicely made of aluminum with rubber strap to keep the battery located in a crash. I say if it hangs out and is located for mass centralization WTF.
    Nov 2014
    Melbourne, Australia
    monster tank and battery mount? piss the airbox off, put pod filters on it and fit the battery at the front of the frame there? otherwise, under the seat.
    Mar 2010
    , IL, .
    It currently has a DP airbox (top cut off) with a fluffy filter (PO didn't replace it recently or he lived with too many cats or dogs. How do they run with pods over the stock air intakes which are pretty large diameter velocity stacks?
    I'm trying to keep the stock ridiculously large and ugly ST tank but I suppose I could flush it out and see if it's possible to create a hollow underneath to squeeze the battery in there.
    Under the seat is probably an easier option even if I chop the lower rear frame rails.
    The original plan was a sort of street tracker thing, but using the latest technology in crayons and paper, I can't make that work aesthetically. I tried a whole series of seats on it and cut down stock or early monster with a new rear hump is still winning. I even tried a Yamaha R7 seat which is almost as wide as the tank, but that makes the back end look heavy.Name:  DSCN4838.JPG
    Mar 2010
    , IL, .
    I just found Brad's blog on fitting pods to an 888 and then found https://www.bellissimoto.com/parts/a...air-intake-kit which says to fit and aftermarket crankcase breather which I thought I read wasn't necessarily an improvement. It would free up that space by getting rid of the breather plenum though, so that's a plus.
    I think I like Brad's approach if I can get my local tool and die guy to machine up a couple of adapters at a reasonable cost.
    Nov 2014
    battery in the airbox?
    Mar 2010
    , IL, .
    You mean sitting where the roof of the OEM airbox would normally be? Hadn't thought about trying to mount it up there. I'll check tomorrow to see if that's possible. Assuming an overnight tornado make it all moot.
    jcw
    jcw is online now
    Senior Member jcw's Avatar
    Jul 2015
    chicago burbs
    Quote Originally Posted by Teazer View Post
    .Name:  DSCN4838.JPG
    This looks good to me.
    If you get one of those 8 cell lithium fe phos batteries, you could put it in the tail without worrying. Small and light.
    I run a 4 cell in my trackbike and it’s like the size of a carton of cigs and almost as light.
    Senior Member steveo's Avatar
    Oct 2013
    Colchester, England
    Don't know if this is of any help.
    Nov 2014
    there's no room under the st tank for that.
cafe st3
