CB750 4 Scorpian Trellis frame rebuild downunder
This is a discussion on CB750 4 Scorpian Trellis frame rebuild downunder within the Project Builds forums, part of the Caferacer.net Forums category; Purchased this frame over the internet in a whim a few years back with little to no knowledge about its origins or history the photo ...
Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Like Tree6Likes
Thread: CB750 4 Scorpian Trellis frame rebuild downunder
    Junior Member dummydownunder's Avatar
    Dec 2019
    the photo is from the original advertisement
    the vendor would not give up the pipes the wheels
    ended up the front end went in the trash some Suzuki bent and buckled rubbish
    engine is almost complete now running methanol mechanical injection hillborn and 40mm webber's for the street
    front and rear ends are to be cbr954 front cbr600 rear and thats all sorted
    ignition is via ARD magneto its been all put together and now pulled back down ONE MORE TIME ! for paint
    frame is marked scorpion 01 and i believe it to of come from some brothers in Queensland the Turner bothers
    i have photos of the entire rebuild and will post as i go dont want to do a full reveal till its done !
    TrialsRider likes this.
    Senior Member Teazer's Avatar
    Mar 2010
    , IL, .
    I can't remember who pulled up at Broadford years ago with Hillborn injection on a CB750 to run in P5. Was it Glen Corrish perhaps? I don't recall now but it looked wicked.
    It would be nice if those mechanical injectors and pump could be replaced with modern electronic injectors and driver and disguised if necessary. Maybe use a Microsquirt with 6 or 12 hole injectors for cleaner burn and more power.
    Forks look like Suzuki GT750 75-77 models.
    Dec 2019
    yep piss and dribble injection is a pain at best but we hope to run it on the salt lakes later so there with WOT it will be just dandy !
    tank mods to lower it over frame with twin fuel cocks
    tank notched to clear 954 forks
    Quote Originally Posted by dummydownunder View Post
    lol for the street!
    To be totally honest
    from the first time I seen your frame I thought it looked pretty skinny in the backbone trellis. :| because it appears to be half a trellis short.
    Dec 2019
    lol for the street!
    yer the street he has a headlight and turn indicators and a sweet tail lamp !
    Mar 2010
    , IL, .
    Love the Peter Brock stickers on the tool chest. Do you have a Torana to go with them? Whatever happened to his race cars and the Alan Moffat Falcons ?
    Dec 2019
    Quote Originally Posted by Teazer View Post
    here is a link to a museum you will like >>> National Motor Racing Museum - Home
    loads all over the place the cars that is and no Torana.......
    but i have its big brother the HR "hell razor" ute
    here are the shitty mechanical injection pump brackets getting replaced and up graded
    Mar 2010
    , IL, .
    HR Ute brings back memories. First car I had in OZ was an HR 186 with 2 speed powerglide IIRC station wagon and when it lost top gear, it was time to let it go. I only went to Bathurst once as a spectator and it was insane - concrete walls right up to the side of the circuit, a 100+mph jump and Murray's corner where Ross Barrelli (sp?) died half way across the parking lot when his brakes failed was sensory overload. I could not imagine how brave riders were to race there back then. Boulden, Hansford, Sayle, Niel, Croz, Willing and so on. Those guys with virtually no padding in their race leathers, no airbags and carbon fiber boots and zero run off area or air fences.
    Still not sure how they managed to fit their huge balls on a bike.
    Remember seeing the Ford 1-2 on TV and I worked at Ford back then, so that was a happy day.
    Now where were we? Oh yes, what fuel pressure does the old mechnanical pump generate and could it be upgraded with say a diesel pump or an early European auto pump to increase delivery pressure - or maybe it's enough already. A system with electrical opening and constant pressure in the rail has to be easier to control with pulse width.
    At least Metho is pretty tolerant of air:fuel mixture ratios - as long as it's too much it's enough.
    Dec 2019
    things its upwards of 100psi but even thou its all set up that will need sorting so webbers will be on for start up
    got more done on fame today here today's update pic
    Oct 2009
    Laredo, Texas
    Great build, keep it up!
    GrandPaul
    Author, \"Old Bikes\"
