N00b Intro
N00b Intro
This is a discussion on N00b Intro within the Project Builds forums, part of the Caferacer.net Forums category; All, Figured I'd give a quick intro: I just acquired a CL450 (Hopefully picking it up this weekend !), and have the usual plans to ...
Results 1 to 5 of 5
Thread: N00b Intro
    SteveH's Avatar
    Aug 2007
    N00b Intro
    All,
    Figured I'd give a quick intro: I just acquired a CL450 (Hopefully picking it up this weekend !), and have the usual plans to cafe it a bit.
    Background: I started my motorcycle life off with a nice CB360T, which I sold two days after completing it (Got made an offer I couldn't refuse...). Ever since then I always wanted something close to it; but perhaps a little more racy.
    The gods smiled upon me, and granted me this:
    So the plans are for the usual tank/seat/etc. However, I am going to keep the CL front end, along with the high pipes.
    I am interested in ditching the electric start (although I'd probably just core the starter, and leave the shell in place for aesthetics), but I do need enough electric ballos to run lights and blinkers. So Im sure I can get away with a nice small battery under the seat.
    For the most part - what does everyone do for this ? Completely ditch the main harness and make anew, or will the old harness allow for the movement of the reg/rectifier up under the seat ?
    Also I've been looking around at rearsets and found these - anyone give 'em a go ?
    http://www.rearsets.info/FH1.JPG
    They also have some adjustable clubmans that look sweet (yes, I followed the flame posts re:cheap clubmans). Before I restart that; let me state that I will be keeping the stock fork ears; so screw you and your clubman hate-or-ade (that said, my clubmans will prolly cost more than your clipons anyway <img src=icon_smile_tongue.gif border=0 align=middle>..)
    Lastly, I need to decide on color. Right now Im thinking either red/white (ala typical honda)or black/silver. Time will tell.
    Cheers !
    -Steve
    Senior Member xander450's Avatar
    Mar 2007
    Madison, Wisconsin, USA.
    Well buddy, sounds like you've thought this one through. You don't need to completely rewire, you can move regulator/rectifier without ditching the harness (though if you need, I believe I've got a simplified CB450 wiring diagram somewhere around here if you feel like running just the bare necessities). If you go with a lower a/h battery for size purposes you might want to consider a spst switch on one of the three charging circuits - or perhaps consider wiring it into the headlight circuit and then run with your headlight on at all times. Or not, SLAs are cheap and they don't explode (often).
    MG Innovations makes a starter block-off plug to fill the hole where the starter used to be. There's nothing aesthetically pleasing about a heavy-ass lump of shit bolted to the front of an engine.
    A
    Senior Member snorkelfork's Avatar
    Feb 2007
    austin, tx, Zambia.
    those rear sets are nice but way too expensive in my opinion. better to rig some from another bike, try doing a thread search for more on that. dig those pipes.
    ...connoisseur of slack...
    SteveH's Avatar
    Aug 2007
    A
    Ha - point taken. Would be a good spot to keep a sammich or something nice and warm on the way to work tho...
    If you do have that wiring schematic, I'd like it.
    I need to get the carbs rebuilt sometime this week, and I just want to ride the hunk around for a couple of weeks before I begin taking it all apart.
    -Steve
    Mar 2007
    Courtesy of Steve (sprint66 on MSN CB450 site):
    ...or if you don't want lighting:
    Alex
  1. Another n00b joins the group
    By 1965T120R in forum General
    Last Post: 09-11-2012, 05:35 AM
  2. n00B from london
    By Beenie in forum General
    Last Post: 08-27-2008, 03:56 PM
  3. Intro
    By T100abuser in forum General
    Last Post: 03-06-2008, 08:57 PM
  4. Help-A-N00b (pretty much like a charity)
    By ZouLou in forum General
    Last Post: 08-16-2007, 10:48 PM
  5. n00b
    By Burdock in forum General
    Last Post: 08-07-2007, 09:17 AM
