T500 Front Drum Needs Welding
This is a discussion on T500 Front Drum Needs Welding within the Technical forums, part of the Caferacer.net Forums category; Just bought a T500 2LS front drum for my CB350 and it has the telltale hairlines. I'm looking to get it welded/prepped for racing in ...
Results 1 to 4 of 4
    Senior Member busapilot's Avatar
    Jun 2009
    Westminster, Maryland, USA.
    Just bought a T500 2LS front drum for my CB350 and it has the telltale hairlines. I'm looking to get it welded/prepped for racing in the Spring. Any help?
    Located in Baltimore, MD.
    Every time I start thinking the world is all bad, then I start seeing people out there having a good time on motorcycles. It makes me take another look. - S.M.
    and you aren't worried that the places you didn't weld up will crack at some point? At some point where you are leaned over through a fast a corner?
    Craig
    bj
    bj is offline
    Senior Member bj's Avatar
    Jul 2007
    Baltimore, MD, USA.
    I know a lot of guys run these and I thought I'd read that they can be welded to eliminate the possibility of catastrophic failure.
    Sep 2008
    Rochester, New York, USA.
    I've got a lot of aluminum welding hours, and welding a fatigued part is not a good solution at all... you're just restressing the material in different areas and, yeah, could be setting yourself up for a catastrophic failure at some point. It's the same reason planes have airframe hours, aluminum work hardens and will fail in time, the only fix is heat treating, and that's iffy
  1. WTB suzuki T500 front axle bushing
    By kochic in forum Wanted
    Last Post: 05-14-2011, 03:17 PM
  2. how do you hold the backplate on a t500 drum?
    By kochic in forum Technical
    Last Post: 04-16-2011, 03:35 PM
  3. GT750 and T500 Drum Brakes F/S
    By texmawby in forum Parts For Sale
    Last Post: 12-22-2009, 11:04 PM
  4. cb350 front drum / t500 front ?
    By Eric750 in forum General
    Last Post: 10-11-2006, 03:28 PM
  5. cb350 front drum / t500 front ?
    Last Post: 10-11-2006, 02:38 PM
suzuki t500 drum cracking
