pod filters/ jets
pod filters/ jets
This is a discussion on pod filters/ jets within the Technical forums, part of the Caferacer.net Forums category; so i'm thinking about pod filters... this page http://www.crc2onlinecatalog.com/pod_filters.htm says i wouldn't need to rejet the carbs on my cb360... sounds like a lie... anybody ...
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 35
    Senior Member Johnny Gaijin's Avatar
    Jun 2006
    seattle, washington, .
    pod filters/ jets
    this page
    says i wouldn't need to rejet the carbs on my cb360... sounds like a lie... anybody have any insight or experience with this?
    SJW
    SJW is offline
    Senior Member SJW's Avatar
    Jul 2009
    Adanac, , Canada.
    I never rejetted. Runs fine.
    Canada, we\'re bigger and on top. If this were jail you\'d be our bitch.
    Jun 2006
    notice any difference in power? what'd you do with your battery?
    pods on a stock bike (even with rejetting) = no gain or loss of power + loss of driveability.
    not only will you have to rejet but you will most likely have to re-sync the carbs as well. A lot of that has to do with the weather conditions of where you live (density alitutde, etc).
    The majority of japanese bikes from the 1970s are really well engineered, which means all the components are meant to work together and do so quite well. A lot of people see a reduction in hp and torque when switching to pods because the airflow changes (usually due to people shitcanning the velocity stacks inside the airbox). Furthermore most stock bikes can't take advantage of the new "free-er air flow" because the real restriction is in the head.
    You know when I would switch to pods? when I was using better carbs and the stock airbox doesn't work, or when I have a different cam/head porting combination.
    so what am I trying to say here? well Pods suck for a stock bike.
    SJW, fill out your bio.
    isn't that a teensy bit untrue:
    https://www.caferacer.net/forum/topic.asp?TOPIC_ID=11735
    SJW
    SJW is offline
    Jul 2009
    Adanac, , Canada.
    No, the misfiring was due to it being way off time. New head gasket installed plus re-time = beautiful. Until my cam chain thingy broke.
    SJW
    SJW is offline
    Jul 2009
    Adanac, , Canada.
    My battery, since been upgraded to gel.
    SJW
    SJW is offline
    Jul 2009
    Adanac, , Canada.
    Yes im a master with the angle grinder.
    you still need to fill out your bio.
    SJW
    SJW is offline
    Jul 2009
    Adanac, , Canada.
    I can't go around as a man of mystery?
  1. Jets
    By shafdeezy in forum Technical
    Last Post: 12-06-2012, 10:37 PM
  2. CB 750 Jets question
    By mut in forum Technical
    Last Post: 04-15-2012, 09:47 PM
  3. Main Jets?
    By gryffin in forum Technical
    Last Post: 12-25-2009, 02:03 AM
  4. Mikuni jets
    By UngaWunga in forum General
    Last Post: 06-12-2009, 01:54 PM
  5. cool your jets
    By joe c in forum Vintage Motorcycle Racing
    Last Post: 07-09-2007, 07:34 PM
cb360 pod filters
cb360 rejet pod filters
rejetting cb360 carbs
