3 phase bridge rectifier
This is a discussion on 3 phase bridge rectifier within the Technical forums, part of the Caferacer.net Forums category; anyone used one on a cb360? I'm putting mine back together and the original design is just so............. bunglefucked, that I'm thinking of building a ...
Results 1 to 10 of 19
    Sep 2008
    Rochester, New York, USA.
    anyone used one on a cb360? I'm putting mine back together and the original design is just so............. bunglefucked, that I'm thinking of building a box that handles the rectifier, regulator, starter relay (mosfet), etc... if anyone has any suggestions as to why honda only used two phases of the alternator on this bike too, they'd be appreciated
    Nov 2008
    It uses 3 phases, one gets switched in when lights turn on so it doesn't overcharge when lights are off
    PJ
    Nov 2008
    PJ
    Sep 2008
    as far as the regulator, I've been told it shorts to ground when the voltage goes over the limit, this seems like a stupid design, is this so? or does it just break contact with the rectifier?
    Sep 2008
    Jul 2008
    Kenosha, WI, USA.
    Just about every regulator in the world will take the extra voltage and shunt to ground. The current has to go somewhere, which is why they don't open the circuit instead. If you opened the circuit, the voltage would actually rise, which isn't really what you want.
    Dictated but not read.
    Jul 2008
    Kenosha, WI, USA.
    Sep 2008
    ok... if that's the case, I'll definitely be building a switch mode regulator to keep the system voltage at or below 13 or so. should take some load off the alternator too since it will just modulate the output without shorting anything to ground
    Sep 2008
    Nov 2008
    I guess that's the difference between electronics and electrical systems, knows how to build a switched regulator but doesn't know what it does
    It wont take any load off a PMS system, the magnet still spins.
    PJ
  1. Top fork bridge for sale anyone?
    By oscarrico12 in forum General
    Last Post: 10-11-2011, 12:59 AM
  2. Covered Bridge Tour Aug 14 NY
    By JackC in forum General
    Last Post: 07-05-2010, 09:17 PM
  3. MT125R Top Fork Bridge Needed
    By Hoosier Tom in forum Wanted
    Last Post: 02-10-2009, 11:26 PM
  4. The Bridge Is On Fire!!!
    By 2smokeTyler in forum General
    Last Post: 09-05-2008, 01:43 AM
  5. stupid 3 phase power
    By joe c in forum General
    Last Post: 04-12-2007, 08:59 PM
3 phase rectifier on cb360
